berkhoff
Multiple EoIP tunnels or VLANs
Sun Sep 18, 2016 12:08 pm
Trying to bridge two sites carrying several VLANs. Should I create one EoIP tunnel per VLAN or should I create a single tunnel with multiple VLAN interfaces?
Or should I follow some different approach? Please advise.
Thanks!
Mark
docmarius
Re: Multiple EoIP tunnels or VLANs
Sun Sep 18, 2016 12:36 pm
I think the best answer to this is "as you wish". Although it is easier to manage one tunnel instead of several ones.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
scampbell
Trainer
Trainer
Sat Sep 24, 2016 5:57 am
Beware of mtu's though. if you push multiple vlans through an eoip tunnel you decrease the mtu as the vlan headers take up 8 bytes.
Sent from my iPhone using Tapatalk
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
Users browsing this forum: No registered users and 25 guests
