jeroenp
[Mikrotik documentation needed] Firewall connection tracking enabled auto vs yes - what's the difference?
Thu Oct 06, 2016 4:14 pm
Since mikrotik firewall connection tracking enabled auto vs yes doesn't return meaningful results and http://wiki.mikrotik.com/wiki/Manual:IP ... g_settings doesn't explain the difference between `auto` and `yes`:
What's the difference between `auto` and `yes` for the `/ip firewall connection tracking enabled` setting?
Background: YouTube video How to redirect DNS to own DNS server using mikrotik routerboard advices to turn it from `auto` to `yes`: why would that be?
--jeroen
jarda
Re: Firewall connection tracking enabled auto vs yes - what's the difference?
Thu Oct 06, 2016 6:29 pm
Auto means off by default until some other feature needs it. Typically firewall....
jeroenp
Thu Oct 06, 2016 8:56 pm
So what features need it?
And what features that don't need it can benefit from it?
--jeroen
IntrusDave
Thu Oct 06, 2016 9:26 pm
It will auto-enable when you add NAT rules.
You can force-enable if you want filter rules without NAT.
David Joyce
Network & Security Engineer
Intrus Technologies, LLC.
Rancho Cucamonga, CA, USA
jeroenp
Fri Oct 07, 2016 11:54 pm
Thanks. Someone should add that to the docs.
--jeroen
Users browsing this forum: No registered users and 36 guests
