AlexG
[SOLVED] USB flash not showing up
Tue Oct 25, 2016 8:43 pm
I've just purchased my first Mikrotik device (CRS109-8G-1S-2HnD-IN) and I'm having trouble seeing the attached USB flash drives via the OTG cable. I've tried with 3 different USB drives and none of them show up in
/disk print
nor in WebFig. Even tried
/system routerboard usb set usb-mode=force-host
and still no luck.
One thing I saw that after connecting the flash drive, the LED from the drive lights up for 2 seconds and then it goes off.
I'm running the latest current release (6.37.1).
Any clues on what may be the issue?
Thanks!
Splash
Re: USB flash not showing up
Wed Oct 26, 2016 11:01 am
Can you check you are running the latest firmware on the CRS device?
Does the device show up in the USB list?
/system resource usb print
MTCNA, MTCRE, MTCINE, MTCTCE, MTCIPv6E, MTCUME
ppihus
Wed Oct 26, 2016 12:28 pm
Are your devices USB 3.0 or 2.0?
I'm having a similar issue and currently it seems that all USB 2.0 flash drives that I have are working great, but any of the USB 3.0 drives are not recognized anywhere, including 'system resource usb print'. I've also tried automatic and force-host modes.
Reformatted the all the disks in virtually every possible way but still no luck.
Working:
4 different USB2.0 drives from sizes 4GB to 8GB
Not working:
2 different models (and two of each model) USB3.0 drives. Sizes 16GB and 128GB
So it's probably either USB2.0/USB3.0 or drive size that's currently limiting. But I have RB3011, which should have USB3.0 support.
AlexG
Thu Oct 27, 2016 6:04 pm
@Splash I'm running 6.37.1
Yes, it shows up.
 # DEVICE VENDOR                                                 NAME                                               SPEED
 0 1:1    Linux 3.3.5 ehci_hcd                                   RB400 EHCI                                         480 Mbps
@ppihus
I have 2 USB2.0 and one USB 3.0. None of them work.
AlexG
Re: [SOLVED] USB flash not showing up
Sun Nov 13, 2016 8:10 pm
Apparently, rebooting the router with the USB flash connected solved the issue. After it came up again, I could see anf format the device. I guess it doesn't have hotplug capabilities.
Users browsing this forum: No registered users and 16 guests
