Hello, first up, im sorry for the trouble as I feel overwhelmed with the amount that RouterBoard has to offer and im trying to piece things together but i find it a little confusing.
I would like to setup the Hap AC into a simple switch with wifi support that then relays data to the Main Router.
Ok, so starting with my current setup. Right now (living in Australia) using cable to an Optus (ISP) Router, known as the CG3000v2, is connected to different devices such as a much larger switch and different computers. One of the Ethernet cables from the router is connected to the HAP AC in another room. From there it is connected to other devices in that room. All Wi-Fi devices are connected to the HAP AC. The Ethernet from Optus Router goes into Ether1 port the of HAP AC
So, now onto my config in MikroTik running 6.37.1.
The Quickset mode is set to WISP AP because I have connected the ports in Switch mode by having the ports 1,3-5 set to have ether2 as master port.
I manually set the ip address of MikroTik to 192.168.0.2 which is outside the CG3000v2s DCHP Range (192.168.0.10-192.168.0.209)
Set the Gateway to CG3000v2 which is 192.168.0.1
Set DNS Servers manually matching CG3000v2
Wlan1(2.4Gghz), Wlan2(5Ghz) and Ether2-MasterPort is inside Bridge
None of the DHCP settings are turned on as i wanted the DHCP to be handled by the CG3000v2 but I dont think it is properly?
Firewall Settings are defaulted and not sure if they need to be disabled since there is a firewall on the CG3000v2
The rest of it is left at default.
So right now, wifi works and so does anything connected to it, but i feel as if the settings are not properly set so that it can act like a simple switch with Wifi. I am also experiencing brief Wifi (Not sure on hard wired devices, but seems to happen on both 2.4 and 5Ghz) cut outs that happen every 30 mins. Its really brief and cant tell on webpages and such but on some sensitive apps, its more noticeable.
Thank you very much for any help and sorry for your time.
