MUM Europe 2020
pggarland
new NAT does nothing
Wed Nov 09, 2016 5:41 pm
I am new to the MikroTik, having inherited it. We have a few machines behind the firewall that are accessed through remote desktop. I see the NAT records for those machines, using ports 3395 - 3399. I have been tasked with adding another machine, so I created another NAT record for the new machine using the documentation. However, no matter what I do, I can't connect to the machine from outside the firewall.
Also, if I edit one of the existing NAT records to point to the IP address of the new machine, I can't connect then either.
I have read many comments that say that you have to reboot the router if you change a NAT that has already had a connection, but what about newly added ones? Or is there a way to save the change other than just creating the NAT?
Also, how do you reboot the router from WinBox or the Webfig?
Thanks for any help.
Paul
andriys
Re: new NAT does nothing
Wed Nov 09, 2016 6:48 pm
Please check that you also allowed external access to this machine in the /ip firewall filter.
System -> Reboot
busla
Wed Nov 09, 2016 7:02 pm
Documentation is wrong. You must add allow rule to the input chain of ip->firewall->filter.
janus20
Wed Nov 09, 2016 10:47 pm
I think you need 2 rules: first, a dst-nat in nat chain and second a forwarding rule in filter chain. Let's say that for new machine you wish to alocate port 4000, on mikrotik router, and fordwaring the remote desktop to your new machine 192.168.0.10 on which remote desktop is listening on 3389:
1. dst-nat rule for your destination machine inside your lan ( in our example 192.168.0.10/24)
add action=dst-nat chain=dstnat comment="access remote desktop to machine XXXX" dst-port=4000 in-interface={your_wan_interface} log=yes protocol=tcp to-addresses=192.168.0.10 to-ports=3389
2. accept forward rule in filter chain
add action=accept chain=forward comment="accept remote desktop for machine XXXX" dst-port=4000 in-interface={your_wan_interface} log=yes protocol=tcp
Do not forgive to replace {your_wan_interface} with your real wan interface { ether1, pppoe-out1 .. etc) as well as new machine real ip ( not 192.168.0.10) and move rule 2. above any "drop" rule into filter chain, if any.
This should be enough. Hope it helps.
kind regards,
Chupaka
Thu Nov 10, 2016 2:15 am
make sure that machine has Internet access via that router
you are wrong. this is only needed for accessing router's services (like WinBox, Web Proxy, DNS Server, etc.). all traffic through the router (from the Internet to LAN machines and back) goes via 'forward' chain
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
jarda
Thu Nov 10, 2016 8:03 am
... And be sure the machine is accepting incoming connections from outer world.
busla
Fri Nov 11, 2016 6:50 pm
It work in hundreds installations. - Just check howtos from Google search and comments to them.
Chupaka
Sat Nov 12, 2016 3:05 am
Sure it works. Accepting nothing does not break anything :) I won't google for you
Users browsing this forum: Google [Bot], iisti, mkx, nowinskit, roe1974 and 53 guests
