p4rot
Need help for making a VPN on a Mikrotik router
Wed Nov 09, 2016 7:10 pm
i need help to setup a VPN connection to a Mikrotik router, if anyone can help please let me know.
I tried many tutorials and it never works.
Im able to access the device currently only if im on the same network, as soon as i change my network connection i lose the abiility to access it with Winbox.
If someone could team viewer with me for help on how to do it or help anyway i would apreciate.
Thanks.
olkitu
Re: Need help for making a VPN on a Mikrotik router
Wed Nov 09, 2016 9:44 pm
Hmm... What VPN protocol you like use? Mikrotik support many different VPN protocol.
I recommended you post your config here, you can export your config with /export command on terminal.
Network Specialist
Need know where is cellular tower? Try CellMapper to get know where is cellular tower:
https://www.cellmapper.net/map
erlinden
Thu Nov 10, 2016 12:01 pm
Have you changed your firewall?
You need to accept several ports...
First the problem, then the solution
Users browsing this forum: Google [Bot] and 46 guests
