konix
CSR125 and ping 2 hosts on default configuration
Sat Nov 12, 2016 5:40 pm
Hi!
I just bought CRS125-24G-1S-2HND-IN, I connected 2 laptops to 2 different ports, assign addresses within the same subnet, but hosts can't ping each other. Everything is on default configuration. So far I have been working a little bit with cisco stuff where switch doesn't require any configuration to enable 2 hosts ping each other. Do I have yo configure anything else on the switch ?
Thanks for help.
erlinden
Re: CSR125 and ping 2 hosts on default configuration
Sat Nov 12, 2016 7:09 pm
By default one of the ports is a WAN port. Which ports did you use? Have you tried two other ports?
Users browsing this forum: No registered users and 24 guests
