pkrexer
Can't reach google
Thu Dec 15, 2016 8:35 pm
Hey guys,
I'm just trying to narrow down what the problem might be with one of my clients. They can't reach google for some reason, but everything else works fine. If I try to ping google.com from the router, it resolves but is being redirected back to itself? This might be something simple, but I haven't seen this before.
Could this be an ISP issue?
Here are some screenshots:
tr00g33k
Re: Can't reach google
Thu Dec 15, 2016 9:15 pm
Please poste your routing table, routing rules and magle rules, it looks like routing loop. but this is only to google ? Try to make traceroute to see where the packet start to bounce between two hosts, at least it looks like that.
pkrexer
Thu Dec 15, 2016 9:46 pm
The mangle rules are used for queue tree. I disabled them already just to make sure, had no affect.
Here are the trace routes.
Google:
Yahoo:
tr00g33k
Thu Dec 15, 2016 10:01 pm
The only time that this happens is to google? Do you maybe have some firewall rule related to google`s IP, some L7 google firewall rule? Address list? From what i see i wouldnt say it is a ISP problem it looks like the packet doesnt go out from router, could you paste whole config, to see what could it be.
What if you try to do tracerotue from behind the router, from some host on LAN ?
pkrexer
Thu Dec 15, 2016 10:34 pm
It is only google that this is happening to.
Don't have any Layer7 stuff going on or firewall rules that would be trying to redirect / block google related ip addresses.
Still at a loss.
# dec/15/2016 11:15:06 by RouterOS 6.36.4
# software id = A8XP-J0T1
add arp=proxy-arp mtu=1500 name="HVAC Bridge"
add mtu=1500 name="Main Bridge"
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether6 ] comment="HVAC System"
set [ find default-name=ether7 ] comment="HVAC System 2"
/interface eoip
add clamp-tcp-mss=no disabled=yes !keepalive mac-address=02:07:DF:4D:3E:D9 \
    mtu=1500 name="EoIP Waara" remote-address=x.x.x.x tunnel-id=xxxx
/ip neighbor discovery
set ether6 comment="HVAC System"
set ether7 comment="HVAC System 2"
add name=dhcp ranges=192.168.1.100-192.168.1.199
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add address-pool=dhcp disabled=no interface="Main Bridge" lease-time=30m \
    name="Main DHCP"
add address-pool=dhcp_pool1 disabled=no interface="HVAC Bridge" lease-time=3d \
    name="HVAC DHCP"
/port
set 0 name=serial0
/ppp profile
set 1 local-address=dhcp_pool1 remote-address=dhcp_pool1 use-encryption=\
    required use-mpls=yes
/queue tree
add max-limit=50M name=queue_tree_download packet-mark=download parent=global \
    queue=pcq-download-default
add max-limit=3500k name=queue_tree_upload packet-mark=upload parent=global \
    queue=pcq-upload-default
add bridge="Main Bridge" interface=ether2
add bridge="Main Bridge" interface=ether4
add bridge="Main Bridge" interface=ether5
add bridge="HVAC Bridge" interface=ether6
add bridge="HVAC Bridge" interface=ether7
add bridge="Main Bridge" interface=ether8
add bridge="Main Bridge" interface=ether9
add bridge="Main Bridge" interface=ether10
add bridge="Main Bridge" interface=ether11
add bridge="Main Bridge" interface=ether12
add bridge="Main Bridge" interface=ether13
add bridge="Main Bridge" interface=ether14
add bridge="Main Bridge" interface=ether15
add bridge="Main Bridge" interface=ether16
add bridge="Main Bridge" interface=ether17
add bridge="Main Bridge" interface=ether18
add bridge="Main Bridge" interface=ether19
add bridge="Main Bridge" interface=ether20
add bridge="Main Bridge" interface=ether21
add bridge="Main Bridge" interface=ether22
add bridge="Main Bridge" interface=ether23
add bridge="Main Bridge" interface=ether24
add bridge="Main Bridge" interface=ether3
add bridge="Main Bridge" interface="EoIP Waara"
set 0 dscp-based-qos-dscp-to-dscp-mapping=no
set 1 dscp-based-qos-dscp-to-dscp-mapping=no
set 2 dscp-based-qos-dscp-to-dscp-mapping=no
set 3 dscp-based-qos-dscp-to-dscp-mapping=no
set 4 dscp-based-qos-dscp-to-dscp-mapping=no
set 5 dscp-based-qos-dscp-to-dscp-mapping=no
set 6 dscp-based-qos-dscp-to-dscp-mapping=no
set 7 dscp-based-qos-dscp-to-dscp-mapping=no
set 8 dscp-based-qos-dscp-to-dscp-mapping=no
set 9 dscp-based-qos-dscp-to-dscp-mapping=no
set 10 dscp-based-qos-dscp-to-dscp-mapping=no
set 11 dscp-based-qos-dscp-to-dscp-mapping=no
set 12 dscp-based-qos-dscp-to-dscp-mapping=no
set 13 dscp-based-qos-dscp-to-dscp-mapping=no
set 14 dscp-based-qos-dscp-to-dscp-mapping=no
set 15 dscp-based-qos-dscp-to-dscp-mapping=no
set 16 dscp-based-qos-dscp-to-dscp-mapping=no
set 17 dscp-based-qos-dscp-to-dscp-mapping=no
set 18 dscp-based-qos-dscp-to-dscp-mapping=no
set 19 dscp-based-qos-dscp-to-dscp-mapping=no
set 20 dscp-based-qos-dscp-to-dscp-mapping=no
set 21 dscp-based-qos-dscp-to-dscp-mapping=no
set 22 dscp-based-qos-dscp-to-dscp-mapping=no
set 23 dscp-based-qos-dscp-to-dscp-mapping=no
set 24 dscp-based-qos-dscp-to-dscp-mapping=no
set 25 dscp-based-qos-dscp-to-dscp-mapping=no
/interface pptp-server server
set authentication=chap,mschap1,mschap2 enabled=yes
add address=x.x.x.122/29 comment="default configuration" interface=\
    ether1-gateway network=x.x.x.120
add address=192.168.1.250/24 interface=ether2 network=192.168.1.0
add address=192.168.10.1/24 interface="HVAC Bridge" network=192.168.10.0
add address=192.168.1.0/24 dns-server=192.168.1.10 domain=NorthSummit.local \
    gateway=192.168.1.250
add address=192.168.10.0/24 dns-server=192.168.10.1 domain=NorthSummit.local \
    gateway=192.168.10.1
set allow-remote-requests=yes servers=208.67.222.222,208.67.220.220
add chain=input protocol=icmp
add chain=input dst-port=8291 protocol=tcp
add chain=input dst-port=1723 protocol=tcp
add chain=input protocol=gre
add chain=input connection-state=established
add chain=input connection-state=related
add action=drop chain=input in-interface=ether1-gateway
/ip firewall mangle
add action=mark-packet chain=postrouting comment="upload mark packet" \
    new-packet-mark=upload out-interface=ether1-gateway
add action=mark-packet chain=prerouting comment="download mark packet" \
    in-interface=ether1-gateway new-packet-mark=download
add action=masquerade chain=srcnat out-interface=ether1-gateway
add action=dst-nat chain=dstnat dst-port=xxxx in-interface=ether1-gateway \
    protocol=tcp to-addresses=192.168.1.179 to-ports=80
add action=dst-nat chain=dstnat dst-port=xxxx protocol=tcp to-addresses=\
    192.168.1.179 to-ports=5445
    192.168.1.179 to-ports=8201
    192.168.1.179 to-ports=59012
    192.168.1.179 to-ports=59011
    192.168.1.10 to-ports=3389
add action=dst-nat chain=dstnat comment="marina wap" dst-port=xxxx protocol=\
    tcp to-addresses=192.168.1.226 to-ports=8291
    192.168.1.238 to-ports=80
    192.168.1.239 to-ports=80
    192.168.1.240 to-ports=80
    192.168.1.241 to-ports=80
add action=dst-nat chain=dstnat comment="3rd floor wap" dst-port=xxxx \
    protocol=tcp to-addresses=192.168.1.220 to-ports=8291
    protocol=tcp to-addresses=192.168.1.97 to-ports=8443
add action=dst-nat chain=dstnat comment=NVR dst-port=xxxx protocol=tcp \
/ip proxy
set cache-path=web-proxy1
add distance=1 gateway=x.x.x.121
/lcd
set time-interval=hour
/ppp secret
add name=hvac password=xxxxx profile=default-encryption routes=\
    "192.168.10.0/24 x.x.x.122 1" service=pptp
add name=mike password=xxxxx profile=default-encryption routes=\
/system clock
set time-zone-name=America/Detroit
/system identity
set name="CenterPointe Main"
/system leds
set 0 interface=sfp1
/system ntp client
set enabled=yes primary-ntp=129.6.15.30 secondary-ntp=64.113.32.5
/system scheduler
add interval=10m name=hairpin_update on-event=hairpin_update policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive start-time=\
    startup
/system script
add name=hairpin_update policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive source="# get t\
    he current IP address from the internet (in case of double-nat)\r\
    \n/tool fetch mode=http address=\"checkip.dyndns.org\" src-path=\"/\" dst-\
    path=\"/dyndns.checkip.html\"\r\
    \n:local result [/file get dyndns.checkip.html contents]\r\
    \n\r\
    \n# parse the current IP result\r\
    \n:local resultLen [:len \$result]\r\
    \n:local startLoc [:find \$result \": \" -1]\r\
    \n:set startLoc (\$startLoc + 2)\r\
    \n:local endLoc [:find \$result \"</body>\" -1]\r\
    \n:global currentIP [:pick \$result \$startLoc \$endLoc]\r\
    \n\r\
    \n/ip firewall nat set [find comment~\"hairpin\"] dst-address=\$currentIP"
Engitech
Trainer
Trainer
Fri Dec 16, 2016 12:45 am
and
----->>> set ip on bridge not on ether2
Van9018
Long time Member
Long time Member
Fri Dec 16, 2016 2:04 am
In Winbox > New Terminal, paste this: :put [:resolve "google.com"] Does it resolve correctly? (or resolve to your ether1 IP?)
I'm guessing it resolves correctly.
You're using a bridge but IP is assigned to ether2 instead of the bridge. Although I doubt this is the issue since most other traffic works.
You also have a script referring to updating a hairpin firewall rule. But I don't see that rule in your config. Do you have one? Your ping to google is getting stuck at ether1. Something (maybe a hairpin rule) is causing the Mikrotik to decide to re-route the ping back to itself where it repeats this until the TTL value is depleted.
If you do a packet capture or torch in Mikrotik, check that the icmp ping packet has the correct IP (which I'm better it does) but also check the dst mac address it has when trying to leave ether1. Dst mac address should be that of your gateway (you can find gateway's mac in IP > Arp).
pkrexer
Fri Dec 16, 2016 6:59 pm
So after digging more into it... Its not "all of google" its only if google resolves to a particular IP. If it resolves to 216.58.192.142, that is when its looped back. If it resolves to something else i.e 216.58.216.238, it works fine and I can ping google.com
So something about 216.58.192.142 it doesn't like.
This is all I see when I try to do a torch:
pkrexer
Fri Dec 16, 2016 10:03 pm
Sorry for wasting your time... Modem just needed rebooted *face palm*
Users browsing this forum: Majestic-12 [Bot] and 54 guests
