ybhanscs
IP Route not working
Mon Dec 19, 2016 9:09 am
I have a topology:
and my ip route configuration:
ping result:
can you help me, please? what do I miss in my configuration? thank in advance.
pukkita
Trainer
Trainer
Re: IP Route not working
Mon Dec 19, 2016 12:30 pm
Please post
/ip address export
/ip firewall nat export
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
scampbell
Trainer
Trainer
Mon Dec 19, 2016 9:13 pm
Please check your cisco will actually reply to an ICMP Ping ?
Also check if the interface the IP address 22.22.22.1/24 is attached to is active. If not then the IP may also not be active.
What about pinging 22.22.22.2 ? does this work ? What about traceroute ?
The cisco is physically attached to both subnets so routing should be ok. Does the PC have 22.22.22.1 as it's default gateway ?
The rule is you need a route to the host and the host needs a route back :-) (and no firewall's stopping your tests)
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
ybhanscs
Tue Dec 20, 2016 9:37 am
Please post
/ip address export
Users browsing this forum: No registered users and 34 guests
