krillin678
HTTPS port 443 help
Wed Jan 18, 2017 4:05 am
Hello friends,
I just received a mikrotik hap ac lite and have been just using it out of the box with no real tweaks yet and I am getting HTTPS errors on some sites. "NET::ERR_CERTIFICATE_TRANSPARENCY_REQUIRED" is the error chrome spits out. I have looked around for a solution to this but most of what I have been able to find relates either to accessing the web config through ssl or making transparent proxies. I don't really plan to implement such things so I was wondering what sort of setting I might need to change in order to get the ssl/https thing working.
Thanks for your help.
p3rad0x
Long time Member
Long time Member
Re: HTTPS port 443 help
Thu Jan 19, 2017 12:51 pm
Goto IP --> services and check if anything is running on 443, if it does just change it to 444
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
tclafoe
Thu Jan 19, 2017 6:14 pm
If it is only the Chrome browser that spits that out - you might find this article helpful: https://sslmate.com/blog/post/ct_redaction_in_chrome_53
krillin678
Fri Jan 20, 2017 4:35 pm
Again, thanks for your help.
I don't know exactly why but it appears to be working now despite no changes that I have made. Although, the layout for this particular setup is Pc-> mikrotik-> fiber router-> internet and I have changed the connection style between the fiber router and mikrotik to be a dmz one and it must have took a while to sync up those settings but it now seems to work.
Users browsing this forum: anav and 34 guests
