hooyao
[SOLVED]2 WAP-ACs can't work together, and not accessible, blame ESXI
Mon Feb 20, 2017 6:40 pm
I have 2 RBwAPG-5HacT2HnDs to setup a home wifi, and I'm trying to test these APs with RouterOS in Exsi before wiring them to real RB2011.
but these 2 APs can't be connected to the RouterOS router at the same time, if only one AP is connected, every thing is good. But once the 2nd AP is connected, usually the 1st one will be "kicked out", be inaccessible, the 2nd AP is unstable as well.
This issue has nothing to do with CAPSMAN or wireless, the problem is I can't let 2 non-router RouterOS live in the same subnet.
the topology is
vmnic 4/5 connected to 2 WAPs, MATLAB is where I manipulate winbox, MATLAB is working great, accessible to internet.
the RouterOS router setup is very simple, it plays as a secondary router after a real RB2011 which is functioning, and these 2 WAPs are hooked directly to this ESXI router
add name=bridge1
/ip neighbor discovery
set ether1 discover=no
set ether2 discover=no
set ether3 discover=no
add name=dhcp ranges=192.168.2.10-192.168.2.100
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
add address=192.168.2.1/24 interface=ether2 network=192.168.2.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.2.0/24 gateway=192.168.2.1 netmask=24
/system identity
set name=CAPSMAN
these 2 APs setup is simle as well, both are identical except admin-mac
add admin-mac=E4:8D:8C:72:AD:83 auto-mac=no disabled=yes name=bridgeLocal
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=wlan2 ] mode=station-pseudobridge ssid=MikroTik
/ip hotspot profile
add bridge=bridgeLocal disabled=yes interface=ether1
add bridge=bridgeLocal interface=wlan1
add bridge=bridgeLocal interface=wlan2
/interface wireless cap
set bridge=bridgeLocal discovery-interfaces=ether1 interfaces=wlan1,wlan2
/ip dhcp-client
/system clock
set time-zone-name=Asia/Shanghai
/system identity
set name=AP83
You can find the solution in POST #4
pukkita
Trainer
Trainer
Re: 2 WAP-ACs can't work together, and not accessible
Mon Feb 20, 2017 6:59 pm
both APs have the same BridgeLocal admin mac?
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
hooyao
Tue Feb 21, 2017 3:29 am
Sorry I missed that part, admin-mac was different. and I have updated the post.
What's other possibilities that may cause my problem?
hooyao
Fri Feb 24, 2017 6:39 pm
I finally figured it out, this issue is caused by esxi's vswitch.
I will show that's not working and what's finally working
NOT WORKING
modem -> vmnic0 -> vswitch0-> ether0 -> RouterOS -> bridge -> ether1 -> vswitch1 -> vmnic1 -> wap
\-> vmnic2 -> another wap
even promiscuous mode is accept, it's not working
WORKING
-> ether2 -> vswitch2 -> vmnic2 -> another wap
and set promiscuous mode as accept in every vswitch on esxi.
if bridge is removed from RouterOS, there will be no such issue nor other weird issues.
the following setup works as well.
modem -> vmnic0 -> vswitch0-> ether0 -> RouterOS -> bridge -> ether1 -> vmnic1 -> real switch with rstp and fast port on -> wap
\-> another wap
\-> AP from other brands
but some ap from other brands may fail acquiring IP from DHCP.
anyway, using RouterOS on esxi is totally a nightmare.
Users browsing this forum: Google [Bot] and 27 guests
