lutfilailaina
HELP - Share With Hostname
Thu Feb 23, 2017 12:21 pm
anyone help me, i can't access share folder with hostname. but if i access with ip, there are no problem. i use RB750
i have tology like this :
Port 1 : ISP - DHCP Client
Port 2 : LAN for 1st floor and 2nd floor - 192.168.1.0/25
Port 3 : LAN for 3rd floor and 4rd floor - 192.168.1.129/25
I get trouble with share folder if i access with computer name.
ex. from 1st floor ping to 3rd floor with IP and i access with \\xxx.xxx.xxx.xx no problem, but if i can't ping with comp name \\CompName and i can't acces it
Somebody can help me.
Thank's Before
erlinden
Re: HELP - Share With Hostname
Thu Feb 23, 2017 2:32 pm
Can you post an ipconfig /all. Perhaps clients don't resolve names with the RB750 but instead are using your ISP (or Googles) DNS servers.
soonwai
Thu Feb 23, 2017 5:53 pm
What are you using for DNS server?
janus20
Thu Feb 23, 2017 11:40 pm
Are all pc/laptop from 1st-4rd floor into the same WORKGROUP/DOMAIN ?
kind regards,
lutfilailaina
Fri Feb 24, 2017 5:50 am
kind regards,
all pc set into same WORKGROUP, but not in a DOMAIN
lutfilailaina
Fri Feb 24, 2017 5:52 am
i use Google DNS, but i enable for "Allow Remote Requests"
erlinden
Fri Feb 24, 2017 10:22 am
Do you think Google knows about your (internal) hostnames? Well actually...they might :)
Make sure the RB750 is used as the only DNS server on your clients. This way only non-internal hosts are revolved by public DNS servers.
Sob
Fri Feb 24, 2017 5:30 pm
What kind of hostname / computer name we're talking about? Is it:
a) Something registered in DNS. If all your computers use router as DNS resolver, you could have e.g. pc1.my.lan with address 192.168.1.50 in "/ip dns static" and you'd use \\pc1.my.lan to access it.
b) Just a name, not registered anywhere. You're using just \\pc1, which always worked fine in same LAN.
If the answer is a), then it should work. If it's b), then it can't just work by itself. You'd need to either set static DNS entries as described in a), or you'd need to have WINS server and let all computers register their names there.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
null31
Sat Feb 25, 2017 6:58 pm
You can try do this to add static dns with the hostname and ip to connect in shares.
> https://wiki.mikrotik.com/wiki/Setting_ ... DHCP_lease
Users browsing this forum: No registered users and 36 guests
