makhariz
Please Help Me: Port Forwarding VIA dynamic ISP?
Mon Mar 06, 2017 10:11 am
Hi good day
Please guys help me. im searching it for a weeks now. reading e-books, watching tutorials in internet and youtube but still i cant find the solution. my problem right now is i just want to access my Local ip address (SIP) via WAN but the problem is my ISP is dynamic. and my mikrotik router is connected to DSL modem.
my network topology is ISP >> DSL MODEM >> MIKROTIK >> USER
jarda
Re: Please Help Me: Port Forwarding VIA dynamic ISP?
Mon Mar 06, 2017 10:25 am
Use some dynamic dns service to register your own domain.
makhariz
Mon Mar 06, 2017 10:42 am
ok! so after i register my domain in dynamic dns service, what should i do next?
janus20
Mon Mar 06, 2017 12:09 pm
After that you should write a script in order to verify/update your dynamic ip then use a scheduler to run script automatically on a period of X minutes/ Y hours ( presuming dls modem is in bridge and mikrotik is making the connection to your isp ).
Here are some links:
a. Dynamic DNS section on Mikrotik viki
https://wiki.mikrotik.com/wiki/Scripts
b. or, you can use dynu.com
https://www.dynu.com/DynamicDNS/IPUpdat ... ynamic-DNS
kind regards,
erlinden
Mon Mar 06, 2017 12:42 pm
And for the forward part, please read:
viewtopic.php?t=50520
makhariz
Mon Mar 06, 2017 1:40 pm
kind regards,
Hi good day.
i can access my mikrotik router thru winbox using changeip.com. its good. but what im trying to say is i want to access my Private IP server. can you please give me some tutorial. step by step so i can understand it clearly?
TIA
pietroscherer
Trainer
Trainer
Mon Mar 06, 2017 2:58 pm
In this case, port forward can be used:
https://wiki.mikrotik.com/wiki/Manual:I ... ernal_host
Pietro Scherer
http://www.tchesolutions.com.br [ISPs Consulting and Training]
http://www.routermage.com [Backup and Automation System]
:D
nescafe2002
Long time Member
Long time Member
Mon Mar 06, 2017 3:36 pm
With the addition that instead of dst-address, dst-address-type=local should be used since the outside address is dynamic.
(Also, you could've just enabled IP cloud for dyndns purposes)
Users browsing this forum: No registered users and 47 guests
