KpuCko
Limited transfer rate on 5GHz - wAP ac
Wed Apr 05, 2017 9:25 am
Hello, i have wAP ac access point (black edition if there is a meaning).
There is a two wireless chips, one for 2GHz and another for 5GHz. I've added two virtual AP's per interface, and everything is working flawless, except i only can get 54MB/s on the 5GHz interfaces.
I try to connect to the AP from different devices - laptop, my mobile phone, the result is the same.
I'm close enough to the AP - 2,3 meters. So i believe there is a misconfiguration, but i don't know where is the problem.
I'm absolute beginner on MikroTik devices, so any help will be usefull.
I've scanned 5GHz channels from my Phone, and everything seems to be fine - there is only one AP in range - my IP.
I've also checked the channels. I can post the output of the command line from my AP.
Thanks a lot.
4  R ;;; Provide access to vlan2 network
      name="wlan_5GHz" mtu=1500 l2mtu=1600 mac-address=6C:3B:6B:6E:45:2A arp=enabled interface-type=Atheros AR9888 mode=ap-bridge ssid="VMK5GHzVLAN2"
      frequency=auto band=5ghz-a channel-width=20mhz scan-list=default wireless-protocol=802.11 vlan-mode=use-tag vlan-id=2 wds-mode=disabled
      wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
      default-client-tx-limit=0 hide-ssid=no security-profile=wpa2-lan compression=no
  channels: 5180/20/a,5185/20/a,5190/20/a,5195/20/a,5200/20/a,5205/20/a,5210/20/a,5215/20/a,5220/20/a,5225/20/a,5230/20/a,5235/20/a,5240/20/a,
            5260/20/a/DP,5265/20/a/DP,5270/20/a/DP,5275/20/a/DP,5280/20/a/DP,5285/20/a/DP,5290/20/a/DP,5295/20/a/DP,5300/20/a/DP,5305/20/a/DP,
            5310/20/a/DP,5315/20/a/DP,5320/20/a/DP,5745/20/a,5750/20/a,5755/20/a,5760/20/a,5765/20/a,5770/20/a,5775/20/a,5780/20/a,5785/20/a,5790/20/a,
            5795/20/a,5800/20/a,5805/20/a,5810/20/a,5815/20/a,5820/20/a,5825/20/a
     ranges: 4920-6100/5/a,an20,an40,ac20,ac40,ac80
  tx-chains: 0,1,2
  rx-chains: 0,1,2
erlinden
Re: Limited transfer rate on 5GHz - wAP ac
Wed Apr 05, 2017 9:59 am
Is 54MB/s your throughput or your connection speed? The latter, I think you mean 54Mb/s, which is indeed to little.
Can you provide some more settings?
quackyo
Wed Apr 05, 2017 10:44 am
"band=5ghz-a".
should be AC .
KpuCko
Wed Apr 05, 2017 11:24 am
"band=5ghz-a".
should be AC .
Aha, thanks a lot quackyo!
Users browsing this forum: No registered users and 26 guests
