Guweili
Cannot access the server MikroTik
Tue Apr 11, 2017 2:20 am
The problem of contact MikroTik server and depend on this image
matiaszon
Re: Cannot access the server MikroTik
Tue Apr 11, 2017 1:19 pm
Open "Neighbors" card in WinBox and see what's there.
Guweili
Tue Apr 11, 2017 2:47 pm
Thank you,
a page stop when the server connection
matiaszon
Tue Apr 11, 2017 2:58 pm
You just physically don't have the connection to your MikroTik.
ITMAN2017
Tue Apr 11, 2017 7:26 pm
Did you try connect to it using MAC Address? :D :D
aarango
Wed Apr 12, 2017 11:07 am
Which is your laptop's IP?
Can you do ping from CMD to that IP?
Which is mikrotik's IP 88 or 100?
satman1w
Wed Apr 12, 2017 12:43 pm
..on Mikrotik router, try another ethernet port... (eth2 instead of eth1...)
regards
normis
Wed Apr 12, 2017 12:48 pm
make sure you are connecting from the LAN side (ports 2...). The first port is firewalled.
Users browsing this forum: No registered users and 46 guests
