MUM Europe 2020
Douglas
MikroTik RouterOS 6.34.2
Thu Apr 27, 2017 8:15 pm
i need someone to Help Me Bypass the Login Page on my Mikrotik Router.
My ISP Refuses to Port Forward. i want to open these ports >> https://support.steampowered.com/kb_art ... -GLVN-8711 the ports on the page.
They keep saying They DO NOT BLOCK PORTS. THEY ARE LYING AND KEEP ON REFUSING SO I NEED TO Bypass the Mikrotik Router Login
p3rad0x
Long time Member
Long time Member
Re: MikroTik RouterOS 6.34.2
Fri Apr 28, 2017 1:38 pm
Good day,
If a ISP block a port its usually port 25.
If port 80 and 443 was blocked, then you won't be able to connect to any web page.
The only way to get into the router is with the username and password, if there was a way to bypass it, then what use is the password?
Now the question is, what makes you think the ISP is blocking the ports?
Is steam unable to connect at all or are you struggling with a game that is unable to join servers?
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
Douglas
Fri Apr 28, 2017 3:46 pm
Good day,
i want to host a game server Left 4 Dead 2 my isp refuses to open ports. go to yougetsignal.com or http://www.ipfingerprints.com/portscan.php and scan which ports are open
IP: 164.160.177.128
p3rad0x
Long time Member
Long time Member
Fri Apr 28, 2017 4:05 pm
Did they give you a reason why they don't want to forward ports for you?
erlinden
Fri Apr 28, 2017 5:32 pm
If your ISP is blocking ports...you are screwed. I'm still a bit puzzled what your ISP has to do with bypassing router login!?
pe1chl
Fri Apr 28, 2017 6:16 pm
Probably his ISP is using MikroTik routers and do not give him the password for it.
Now he wants to do some dstnat and he wants to know how to login to the router.
(of course if he would be able to do that, he would be at a loss configuring a port forward)
Users browsing this forum: Alexdv and 42 guests
