axlpc
how to open tcp 443 ,udp 123 6 devices ?
Wed May 03, 2017 3:43 pm
using 6 device xclaim ap and cloudmanager.
My devices off-line cloudmanager
how to open igmp, tcp 443 and udp 123 ports in mikrotik.
Devices ip adress:192.168.88.14 ,88.15 ,88.16 ,88.17 ,88.18 ,88.19
p3rad0x
Long time Member
Long time Member
Re: how to open tcp 443 ,udp 123 6 devices ?
Wed May 03, 2017 4:37 pm
Hi.
You can only open port 443 and 123 to one of the internal devices.
If you want to open to 6 devices then you will need 6 public IP's setup on your router or you can change the default ports on the remaining 5 devices eg 444 and 124 / 445 and 125 and so on
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
matiaszon
Fri May 05, 2017 4:06 pm
Hi.
He doesn't have to change default ports on devices. Instead of that, he can forward changed public port to default port on device:
1st device: public 443 to local 443 and public 123 to local 123
2nd device: public 2443 to local 443 and public 2123 to local 123
3rd device: public 3443 to local 443 and public 3123 to local 123
etc.
Users browsing this forum: No registered users and 37 guests
