Shankulashvili
i can't install dude server on CCR1036 Router
Fri May 26, 2017 12:49 pm
when i drop npk file tu the router files and reboot it ,, the dude server is not installing ... in logs i see error ther dude server is not installed.. how i can fix it ?
jarda
Re: i can't install dude server on CCR1036 Router
Fri May 26, 2017 9:09 pm
What error is there?
jarda
Shankulashvili
Fri May 26, 2017 10:34 pm
noyo
Fri May 26, 2017 10:59 pm
After upload file npk, reboot! No restore!
pe1chl
Fri May 26, 2017 11:37 pm
You need to upload the same version dude as your RouterOS version on the CCR (which is 6.36.4).
Or upload the new RouterOS version (including all installed optional packages) as well so they will
be updated when the reboot is done.
Shankulashvili
Mon May 29, 2017 1:32 pm
which version i must download and install ? Main package or Extra packages firmware versio (6.39.1) ?
pe1chl
Mon May 29, 2017 2:30 pm
When you don't know that, just upgrade it using the button on the webpage.
Shadeofspirit
Mon May 29, 2017 5:18 pm
You have 6.36.4 on CCR, so you have two variants:
1) update ROS to the latest version and install the latest version of dude
2) download 6.36.4 dude for tile architecture in download archive https://download2.mikrotik.com/routeros ... 4-tile.npk
MTCNA, MTCWE
Users browsing this forum: polhein and 43 guests
