chuky0
ipv6 firewall question
Tue Jun 13, 2017 2:40 am
I was wondering why input chain accept established, related gets no activiy, ie. bytes and packets stay at 0.
Here is an export of my ipv6 firewall, please offer suggestions, critique, etc. Thanks!
"Allow established, related connections" connection-state=\
established,related
add action=accept chain=forward comment="Allow limited ICMP forwarding" limit=\
50/5s,5 protocol=icmpv6
add action=add-src-to-address-list address-list=Whitelist address-list-timeout=\
0s chain=forward comment="Whitelisted sources"
add chain=forward comment="Allow whitelisted hosts and networks" \
src-address-list=Whitelist
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=drop chain=forward log-prefix="v6 DROP INVALID" out-interface=\
ether2-master
add action=accept chain=input comment="Allow established, related connections" \
add action=accept chain=input comment="Allow limited ICMP" limit=50/5s,5 \
protocol=icmpv6
add action=accept chain=input comment="Allow UDP" protocol=udp
"Allow DHCPv6 replies on WAN from link-local" dst-address=fe80::/64 \
dst-port=546 in-interface=ether1 protocol=udp src-address=fe80::/64
0s chain=input comment="Whitelisted sources"
add action=accept chain=input comment="Allow whitelisted sources" \
add action=drop chain=input comment="drop all from WAN" in-interface=ether1 \
add action=accept chain=output connection-state=established,related
add action=drop chain=output connection-state=invalid log=yes log-prefix=\
"v6 DROP INVALID"
proximus
Re: ipv6 firewall question  [SOLVED]
Tue Jun 13, 2017 4:14 am
Sounds like you are applying IPv4 NAT concepts to IPv6. Where in IPv4 NAT, connections on the input chain are TO the router (the NAT address) .. this is the established return traffic to a LAN device request that has been NAT'ed to the WAN address. In IPv6, there is typically no NAT and practically everything is THRU the router (not actually destine TO it), therefore there is nothing on the input chain, just forward chain. So, the only traffic on the input would be something like ICMPv6 probes monitoring the WAN interface, or DHCPv6, etc.
Users browsing this forum: m86895 and 36 guests
