ChipP
Port Forwarding Woes :(
Thu Jun 22, 2017 6:06 am
For some reason, I can't get port forwarding to work to save my life :( No one can connect externally, and until I get that working I don't want to add the hairpin rules just yet.
[admin@XXXXX] /ip firewall nat> print
 0    chain=srcnat action=masquerade out-interface=ether1-WAN-1 log=no
      log-prefix=""
 1    ;;; Windows Server RDP TCP
      chain=dstnat action=dst-nat to-addresses=192.168.0.202 to-ports=3389
      protocol=tcp dst-address=107.x.x.x in-interface=ether1-WAN-1
      dst-port=3389 log=no log-prefix=""
 2    ;;; Windows Server RDP UDP
      protocol=udp dst-address=107.x.x.x in-interface=ether1-WAN-1
 3    ;;; Windows Server GameSvrs 1 TCP
      chain=dstnat action=dst-nat to-addresses=192.168.0.202 to-ports=6001-9999
      dst-port=6001-9999 log=no log-prefix=""
 4    ;;; Windows Server GameSvrs 1 UDP
 5    ;;; Windows Server GameSvrs 2 TCP
      to-ports=25000-50000 protocol=tcp dst-address=107.x.x.x
      in-interface=ether1-WAN-1 dst-port=25000-50000 log=no log-prefix=""
 6    ;;; Windows Server GameSvrs 2 UDP
      to-ports=25000-50000 protocol=udp dst-address=107.x.x.x
 7    ;;; Linux Server Lower Web TCP
      chain=dstnat action=dst-nat to-addresses=192.168.0.250 to-ports=80-3300
      dst-port=80-3300 log=no log-prefix=""
 8    ;;; Linux Server Lower Web UDP
 9    ;;; Linux Server Upper Web Web TCP
      chain=dstnat action=dst-nat to-addresses=192.168.0.250 to-ports=3400-6000
      dst-port=3400-6000 log=no log-prefix=""
10    ;;; Linux Server Upper Web Web UDP
11    ;;; Linux Server WebMin TCP
      to-ports=10000-20000 protocol=tcp dst-address=107.x.x.x
      in-interface=ether1-WAN-1 dst-port=10000-20000 log=no log-prefix=""
12    ;;; Linux Server WebMin UDP
      to-ports=10000-20000 protocol=udp dst-address=107.x.x.x
13    ;;; Joe Dirt RDP TCP
      chain=dstnat action=dst-nat to-addresses=192.168.0.230 to-ports=3390
      dst-port=3390 log=no log-prefix=""
14    ;;; Joe Dirt Games TCP
      to-ports=24100-24299 protocol=tcp dst-address=107.x.x.x
      in-interface=ether1-WAN-1 dst-port=24100-24299 log=no log-prefix=""
15    ;;; Joe Dirt RDP UDP
16    ;;; Joe Dirt Games UDP
      to-ports=24100-24299 protocol=udp dst-address=107.x.x.x
[admin@XXXXX] /ip firewall filter> print
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    chain=forward action=fasttrack-connection
      connection-state=established,related log=no log-prefix=""
 2    ;;; Allow Existing Connections
      chain=forward action=accept connection-state=established,related log=no
      log-prefix=""
 3    ;;; Allow Outbound
      chain=forward action=accept src-address=192.168.0.0/16 log=no
      log-prefix=""
 4    ;;; Allow WindowsServer
      chain=forward action=accept protocol=udp
      dst-port=3389,6001-9999,25000-50000 log=no log-prefix=""
 5    ;;; Allow WindowsServer
      chain=forward action=accept protocol=tcp
 6    ;;; Allow JoeDirt Server
      chain=forward action=accept protocol=tcp dst-port=3390,24100-24299 log=no
      log-prefix=""
 7    ;;; Allow JoeDirt Server
      chain=forward action=accept protocol=udp dst-port=3390,24100-24299 log=no
      log-prefix=""
 8    ;;; Allow LinuxServer
      dst-port=2-3300,3400-6000,10000-20000 log=no log-prefix=""
 9    ;;; Allow LinuxServer
Anyone mind lending a hand?
emikrotik
Re: Port Forwarding Woes :(
Thu Jun 22, 2017 6:40 am
1 to 1 NAT
;;; RDP
chain=dstnat action=dst-nat to-addresses=10.x.x.x to-ports=3389
protocol=tcp dst-address=x.x.x.x in-interface=sfp3 dst-port=3389
Port Redirection
;;; SSH
chain=dstnat action=dst-nat to-addresses=10.x.x.x to-ports=22
protocol=tcp dst-address=x.x.x.x in-interface=sfp3 dst-port=2233
May also have to do with the order your rules are in.
Order should be:
1. NAT Bypass for IPSec tunnels
2. Source NAT rules
3. Destination NAT rules
4. Masquerade
HTH
ChipP
Thu Jun 22, 2017 6:54 am
1 to 1 NAT
;;; RDP
Port Redirection
;;; SSH
Order should be:
2. Source NAT rules
4. Masquerade
HTH
I've already tried reordering (moved the masqurade rule to the bottom) earlier, that didn't help, no one can open a port to anything but the router.
I'll try fowarding the router's port 22 and see if that works.
Hang on, I'm not even forwarding port 22, that rule shouldn't impact anything.
aacable
Thu Jun 22, 2017 9:34 am
Sometimes, few common ports are silently blocked by the upstream providers,
Try PAT, Example forward port 55510 to your local server ip - port 3389
_____________
Regard's
Syed Jahanzaib
Web: http://aacable.wordpress.com
Email: aacable [at] hotmail.com
ajack46
Thu Jun 22, 2017 4:00 pm
But why is that so that the common ports are blocked?
BartoszP
Thu Jun 22, 2017 5:11 pm
Do you have public IP on WAN interface ?
To check if common blocks are blocked try to change the first rule to:
      dst-port=53389 log=no log-prefix=""
so you need to make RDP connection to 53389 port on WAN side. You will see if NAT works.
Real admins use real keyboards.
emikrotik
Mon Jul 24, 2017 3:05 am
To stop people with residential Internet connections hosting mail servers .etc
emikrotik
Mon Jul 24, 2017 3:08 am
1 to 1 NAT
;;; RDP
Port Redirection
;;; SSH
Order should be:
2. Source NAT rules
4. Masquerade
HTH
Where you able to get this working?
If you are testing ssh to the firewall you will have to select the input chain.
ChipP
Mon Jul 24, 2017 5:05 am
1 to 1 NAT
;;; RDP
Port Redirection
;;; SSH
Order should be:
2. Source NAT rules
4. Masquerade
HTH
I did. It seems like something was not working within the router cache or something, after restart it started working with my old configuration :S
Users browsing this forum: Bing [Bot] and 24 guests
