garethiowc
firewall
Wed Aug 02, 2017 7:03 pm
Hi all,
so i've recently passed my MTCNA and i'm really enjoying working with mikrotik hardware.
So i'd like to know a bit more about what i need to do with the firewall to stay safe.
Here is my current config:
add action=drop chain=input comment="Drop DNS on WAN" dst-port=53 \
    in-interface=pppoe-out1 protocol=udp
add action=masquerade chain=srcnat out-interface=pppoe-out1
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
any pointers would be great
I'm planning on doing the rest of the courses at a later date :)
Many thanks
Gareth
pe1chl
Re: firewall
Wed Aug 02, 2017 7:16 pm
Change you rules to drop input from the interface that you really are using for your internet connection.
Apparently PPPoE has been configured but it does not work. When this dump was made from an operational
router, not a router you plan to connect to internet later (and using PPPoE), you need to change that interface.
Users browsing this forum: jvanhambelgium and 24 guests
