ArtyomSh
Is there way to upgrade?
Sat Sep 09, 2017 9:04 pm
Pretty newbie question... Here is the Routerboard screenshot:
Can i upgrade the firmware?
bernd2
Re: Is there way to upgrade?
Sat Sep 09, 2017 9:07 pm
update RouterOS first, then you can upgrade firmware in System -> Routerboard.
Regards
Bernd
ArtyomSh
Sat Sep 09, 2017 9:13 pm
Regards
Bernd
Does my Routerboard support new versions?
Sob
Sat Sep 09, 2017 9:59 pm
Yes. Only unsupported devices so far are old RB1xx and RB5xx.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
ma678
Sun Sep 10, 2017 4:17 am
Does my router download fw from Mikrotik's server directly?
Sent from my SM-G935W8 using Tapatalk
lambert
Long time Member
Long time Member
Sun Sep 10, 2017 10:19 am
Upgrading RouterOS is done under System --> Packages. Like Windows, or OS X on your PC / Mac.
The firmware you are looking at under System --> RouterBoard is equivalent to the BIOS on your PC. That doesn't get updated so often.
After you update RouterOS under System --> Packages and reboot, it may or may not have a new RouterBoard firmware which you can then update under System --> RouterBoard and reboot again.
Users browsing this forum: No registered users and 24 guests
