MUM Europe 2020
Yaraab2044
Link down link up speed 10 ??? Why
Tue Sep 12, 2017 12:41 am
Code: Select all
why?
pcunite
Re: Link down link up speed 10 ??? Why
Wed Sep 13, 2017 1:02 am
Interesting ... sorta port flapping. What is connected on that port?
Jefte
Wed Sep 27, 2017 11:01 pm
I have same problem in some routerboards...;((
Tdaddysimi
Wed Sep 27, 2017 11:20 pm
I had this issue with port 1 of my MikroTik Powerbox. Try lowering the MTU. That was the only resolution I found.
TomjNorthIdaho
Thu Sep 28, 2017 1:50 am
Code: Select all
why?
Check your Ethernet cable on ether4
If you have an Ethernet cable tester , then test it
If you have a crimping tool, cut off both ends and make new ends.
How long is the Ethernet cable ?
Make sure both sides are set for auto auto
djfrancis
Thu Sep 28, 2017 12:03 pm
Code: Select all
why?
You are right, when ethernet goes down and up all time the problem may be:
1.- Bad connectors (make them again)
2.- Bad Cable (replace them)
3.- Distance of cable (max recommended for PoE is about 70-90 meters)
4.- Ethernet interface damaged on external/internal unit
Regards.
fatray747
Sat Aug 04, 2018 4:53 am
I had this problem before.
RB850G connected with two ADSL modems and one AP.
The whole network was not steady, ADSLs disconnect randomly, WiFi lost connection.
After checked the log, I found a lot of link-down and link-up, the interface will be suddenly dropped to 100M and then back to 1G but after some time it will go back to 100M.
I replaced all the cheapy thin flat LAN cables with a branded patch cords.
All problem solved.
Users browsing this forum: No registered users and 43 guests
