TrentendK
Configuring USB modem with Mikrotik HAP lite
Wed Sep 20, 2017 12:49 pm
I am trying to configure a newly purchased Mikrotik HAP Lite router with a ZTE USB modem supplied by a local suppler here in Zanzibar, the provider is Halotel.
When connected the modem appears to be recognized but no port appears. Am I missing a step?
As per forum suggestions I have attached a copy of the supout.rif with the modem connected.
Please advise.
supout1.zip
darkprocess
Re: Configuring USB modem with Mikrotik HAP lite
Wed Sep 20, 2017 1:20 pm
Is it lte or 3g?
TrentendK
Wed Sep 20, 2017 2:42 pm
3G according to the branding.
However, on the Winbox consol it detects as an LTE ZTE unit
TrentendK
Wed Sep 20, 2017 3:52 pm
Also upon opening up the 3g modem it shows to have a model number R6601 if that helps?
darkprocess
Wed Sep 20, 2017 8:24 pm
Create a dhcp client on the interface
darkprocess
Wed Sep 20, 2017 8:25 pm
Create a masquerade nat on the interface also. Don't forget to put the apn and credentials on the interface it self
darkprocess
Wed Sep 20, 2017 8:26 pm
Firts Create a ppp interface using the usb device.
Shadeofspirit
Wed Sep 20, 2017 10:09 pm
Please advise.
supout1.zip
HAP Lite? really? as i know hap lite has usb only for power, it doesn't support connecting usb devices
MTCNA, MTCWE
Shadeofspirit
Wed Sep 20, 2017 10:17 pm
according to your rif file you have Hap AC
ask your provider about the kind of connection.
in some countries you just need to create dhcp client (according to your file on interface lte1)
in other countries you need to create ppp connection on lte1
MTCNA, MTCWE
Users browsing this forum: MSN [Bot] and 32 guests
