MUM Europe 2020
fabmpo
MikroTik RB951 reset issue
Fri Oct 06, 2017 6:45 pm
Hello!
I have a MikroTik router RB951 and amateur network. With WinBox, I reinitialized the configuration without checking the default configuration. there I am utterly lost; there is no signal WIFI and even cable, I can not access to http://192.168.88.1/. I am completely lost. Need help
andriys
Re: MikroTik RB951 reset issue
Fri Oct 06, 2017 7:06 pm
fabmpo
Tue Oct 10, 2017 4:33 pm
Thanks!
The router only lights up with the adapter plugged in. I pressed the reset button for three seconds but still failed
Adrian650
Re: MikroTik RB951 reset issue and 2011
Wed Oct 18, 2017 2:09 pm
I've a similar problem with a 2011. It's been great for a few years but after an update I screwed the config. Did a reset as I've done before and got the display for default admin password suggesting a clean start.
BUT I can't access via 192.168.88.1 and no default WiFi service.
Tried reset a number of times and via 'front panel' reset configuration but always same result.
Any ideas?
matiaszon
Wed Oct 18, 2017 2:23 pm
1. Connect MikroTik via cable to your computer.
2. Run WinBox on your computer.
3. Click on "Neighbors" card.
4. Click "Refresh".
5. Connect with the desired device by MAC address.
Users browsing this forum: oskarsk and 67 guests
