MUM Europe 2020
fxwireless
Mikrotik Port Isolation
Fri Jan 05, 2018 4:33 pm
I'm using firmware version 6.39.
I followed the guide below;
https://wiki.mikrotik.com/wiki/Manual:C ... #Isolation
My config pasted below;
set [ find default-name=sfp1 ] master-port=combo1
set [ find default-name=sfp2 ] master-port=combo1
set [ find default-name=sfp3 ] master-port=combo1
set [ find default-name=sfp4 ] master-port=combo1
set [ find default-name=sfp5 ] master-port=combo1
Still sfp-1 talks to sfp-2-5 instead of only combo1
Could someone help me understand what I'm doing wrong.
Regards,
fxwireless
pe1chl
Re: Mikrotik Port Isolation
Fri Jan 05, 2018 4:50 pm
You did not configure what is indicated on that manual page!
That is only the starting point for further configuration explained on that page.
fxwireless
Fri Jan 05, 2018 6:16 pm
Thanks.
Resolved.
nichky
Long time Member
Long time Member
Sat Jan 06, 2018 12:49 am
new v has many things
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
!) Safe Mode is your friend;
fxwireless
Sat Jan 06, 2018 10:25 am
Okay so I do the same thing on CAS226-24G it stops responding as soon as I put the port isolation rule.
Cant connect via IP or Mac.
Here below are the rules;
set ether1 master-port=sfp-plus1
set ether2 master-port=sfp-plus1
set ether3 master-port=spf-plus1
set ether4 master-port=spf-plus1
set ether5 master-port=spf-plus1
set sfp-plus1 isolation-leakage-profile-override=0
set ether1 isolation-leakage-profile-override=1
set ether2 isolation-leakage-profile-override=1
set ether3 isolation-leakage-profile-override=1
set ether4 isolation-leakage-profile-override=1
set ether5 isolation-leakage-profile-override=1
/interface ethernet switch port-isolation
add port-profile=1 ports=spf-plus1 type=dst [Once I put this rule it stops working]
The same rules worked just fine on the CRS106-1C-5S
Regards,
fxwireless.
Users browsing this forum: No registered users and 51 guests
