ibrahimovich87
Firewall e Nat Rule - FTP Upload
Tue Jan 16, 2018 12:48 pm
need help to configure a FTP (active mode) upload from my server ip 192.168.98.222
that can upload VIA ftp a file outside can anyone help me? Thank you
erlinden
Re: Firewall e Nat Rule - FTP Upload
Tue Jan 16, 2018 1:03 pm
I did a search on this forum, does this topic answer your question?
viewtopic.php?t=61450
ibrahimovich87
Tue Jan 23, 2018 10:36 am
No...i need that an internal IP can upload file, wich rule on firewall i have to make or configure?
Anumrak
Tue Jan 23, 2018 11:21 am
Just create port forwarding rule in NAT, that's all.
ibrahimovich87
Tue Jan 23, 2018 4:21 pm
Sorry...but i can i do it?
ibrahimovich87
Mon Jan 29, 2018 12:53 pm
My fault...what i have to do???
matiaszon
Mon Jan 29, 2018 1:08 pm
If I understand correctly, you want a device inside your LAN to connect to a FTP server in the Internet and upload file? Normally, if there are no specific restricments in the firewall (I guess it's mikrotik in your case), you don't need to do anything. If it doesn't work anyway, it may mean that (1) either the FTP server doesn't accept your connection for some reason, or (2) you have some rules implemented to your NAT/Firewall that don't allow outbond traffic the way you are trying to do. We can help in the 2nd case if you post your settings here.
Users browsing this forum: No registered users and 26 guests
