cressynet
MASTER PORT setting missing
Sat Feb 03, 2018 5:42 pm
Need some help as I have reset my RB960PGS to factory defaults and now when I run WinBox or view via the web interface and I select "Interface List" I cannot see "Master Port" setting which I know has been there in the past and from YouTube tutorials.
2018-02-03 15_17_14-admin@64_D1_54_3A_A2_CD (MikroTik) - WinBox v6.41.1 on hEX PoE (mipsbe).png
cdiedrich
Forum Veteran
Forum Veteran
Re: MASTER PORT setting missing
Sat Feb 03, 2018 5:48 pm
That was introduced with 6.41
If you want to have eth2-eth5 as a switch, add all ports to a bridge, the bridge will take care of hw-offload.
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
acruhl
Sat Feb 03, 2018 5:50 pm
Master port no longer exists as of 6.40. This was due to confusion between master port and bridge, they do the same thing but in different ways in the background.
The new way to do master port is to add interfaces to a bridge. See /interfaces bridge and /interfaces bridge port.
Stuff.
cressynet
Sat Feb 03, 2018 6:11 pm
Thanks thought I was losing the plot.
javierc
Fri May 11, 2018 6:11 pm
Please about this problem can you confirm the substitute command for this?
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 master-port=ether2-master-local name=ether5-slave-local
I readed is can be solved with a bridge, but I use a script for Movistar provider and I need exist this names.
Regards
MangleRule
Fri May 11, 2018 7:21 pm
# Setup a bridge for your LAN ports
/interface bridge add name=local-bridge
# Add your LAN ports to the bridge, by using hw=yes, it will leverage hardware offloading to the switch chip giving the same performance as master > slave
  add bridge=local-bridge hw=yes interface=ether2-master-local
  add bridge=local-bridge hw=yes interface=ether3-slave-local
  add bridge=local-bridge hw=yes interface=ether4-slave-local
  add bridge=local-bridge hw=yes interface=ether5-slave-local
Then instead of setting up your DHCP server and IP addressing on a "master-port" you just use the local-bridge interface instead.
MTCNAMTCREMTCINE | MTCTCE | MTCUME | UBWA
asghar
Sat Sep 08, 2018 3:18 pm
later I was using Bandwidth (Rx/Tx) for limiting speed. what should I now?
Users browsing this forum: andkar, fakhrulraharjo, faxxe, t3jrH and 85 guests
