tiego
Hotspot Status Page not Popup
Mon Feb 05, 2018 12:38 pm
actual on my hotspot on sucessfull login the status page not Popup.
how i can activat this, i need it to give the users the posibility to logout.
i dont can tell it to open "IP"/status ...
some solution?
thanks
freemannnn
Long time Member
Long time Member
Re: Hotspot Status Page not Popup
Mon Feb 05, 2018 1:02 pm
maybe popup blocker blocks the window to appear.
you can manual open it by typing the ip address of hotspot. like 10.5.50.1
tiego
Mon Feb 05, 2018 1:32 pm
its not posilble a oder solution?
giorgiop
Mon Feb 05, 2018 7:28 pm
use the DNS Name you created while setting up the hotspot
using ip-->hotspot-->server profiles, open your server profile and check the DNS Name that you used. After that, just try opening that name from a hotspot client (no http:// needed) for status or dsnname/logout to immediately log out
For example, if the name is hotspot.test, then navigating to hotspot.test will popup the status page, while hotspot.test/logout will log you out
Users browsing this forum: No registered users and 40 guests
