austinhci
Can not get Netinstall to Install packages or routeros.
Thu Feb 08, 2018 5:33 pm
I get the routers to show up in Netinstall and choose my packages but when I press Install it does nothing. The "Ready" will disappear for around 5 seconds then come back up. I've tried it on two computers now. I've tried even Netinstalling different routers that I know are working but it won't install the packages or the routeros. I've looked up guides and read the wiki. Maybe I'm just overlooking something simple.
I'm trying to unbrick some SXT routers that are stuck in a continuous boot loop. I can take some screenshots for you guys if that will help.
I've also opened a ticket with mikrotik support but have not got a response in over a week.
CZFan
Re: Can not get Netinstall to Install packages or routeros.
Sat Feb 10, 2018 2:23 am
had a similar problem once and this is what i did:
  • disable "ALL" other network interfaces, including vpn, virtualbox, wirerless, etc
    disable all firewall
    disable all anti-virus
    make sure you have a good cable
    configure pc NIC for static IP, i.e. 192.168.88.10/255.255.255.0, dont need gateway
    make sure net booting settings are correct in netinstall, i.e. use 192.168.88.10 for pc
    run net install
    press reset button and hold in
    power up router while holding reset button in as per above
MTCNA, MTCTCE, MTCRE & MTCINE
LucZWFM
Mon Feb 12, 2018 11:01 am
I just had the same issue...
Did you connect te router directly to your PC? If so, connect it via a switch...
Windows doesn't always bring up the NIC when there is no link...
Volunteer Techie @ZuidWest FM / ZuidWest TV, Stichting Repeater Bergen op Zoom & WRLP CB Repeater
austinhci
Mon Feb 12, 2018 5:24 pm
Hey guys thanks for the ideas! This worked out for me.
What I did was programmed a RB951 as a plain switch and ran the SXT through that. Netinstall worked flawlessly after I was going through the switch!
It's weird how one month netinstall will work just fine and then nothing seems to work.
Thanks again!!
LucZWFM
Mon Feb 12, 2018 9:21 pm
Thanks again!!
You're welcome...
donsergio
Fri Feb 16, 2018 5:11 pm
Hi, other way is use windows xp... I always get troubles with win7 64 bit but I have a notebook for that.
Regards!!
austinhci
Sat Feb 17, 2018 12:42 am
I'm using windows 10. Whats weird is that I was able to netinstall before on this same laptop a while back. Just recently tried to fix these routers and was only able to get netinstall to work by going through a different mikrotik which was setup as a switch.
burnduck
Mon Sep 24, 2018 8:29 pm
This helped me on Windows 10 too.
This is absolutely baffling - netinstall sees the device but did nothing when I clicked install.
vandrigos
Sat Feb 02, 2019 2:40 pm
    run net install
WORKINGGG FINE, Ty broo!
Users browsing this forum: No registered users and 31 guests
