gargiulo5000
Mikrotik RB941-2ND-TC: VPN Throughput
Fri Feb 16, 2018 6:42 pm
I've discovered Mikrotik and there's an aura of awesomeness all around there.
With that said, i want to buy this router to use it with a VPN provider with wathever protocol (PPTP, OpenVPN...) to ensure that all the connections that are coming to the router are forwarded to the VPN provider (wathever provider it is (tunnel bear, hide my ass etc)).
Do you guys know if this router is capable of a decent throughput doing this kind of things?
Many thanks and thanks for the awesomeness.
jarda
Re: Mikrotik RB941-2ND-TC: VPN Throughput
Fri Feb 16, 2018 6:48 pm
What is decent throughput for you?
gargiulo5000
Sat Feb 17, 2018 9:11 am
Hey thanks for the reply!
I will need like 30 - 40Mbit/s.
Do you guys think that I will achieve this speeds?
Many thanks to all.
Kind regards
JohnTRIVOLTA
Sat Feb 17, 2018 12:35 pm
Many thanks to all.
Kind regards
Rather around 20Mbit/s with aes128cbc !
jarda
Sat Feb 17, 2018 1:12 pm
Don't expect more. If you need ipsec performance then you can select one of the devices with hw aes encryption acceleration. For example 750Gr3, if you would like to stay at low cost.
chechito
Sat Feb 17, 2018 6:47 pm
Many thanks to all.
Kind regards
yes i agree max 20mbps you can expect, keep in mind rb941 is almost the cheapest mikrotik device
if you can wait go for the new upcoming hAP ac2 will be good purchase, almost 6 times the cpu performance of the rb941 and has ip-sec hardware acceleration
and also a more powerful wifi radio in 2ghz and a second additional wifi radio in 5ghz
ethernet ports are gigabit
all that for only 70 US
https://i.mt.lv/routerboard/files/hAP_a ... 162454.pdf
gargiulo5000
Mon Feb 26, 2018 12:01 pm
Ok guys,
i'm about to buy the 750Gr3.
But i'm a little confused on how all this is gonna work.
I've got the VPN provider that is going to give me some configuration for LT2P over IPSEC to put on RouterOS.
Assuming that everthing is going to work fine, i will be able to connect more than one device to the router (or the access point connected to the rotuer) and use the encrypted connection on all the devices simultaneously?
Thanks for the reply.
sindy
Sat Mar 31, 2018 12:48 am
You will be able to connect more than one device to the LAN side of the router and use the L2TP connection for all of them if the router itself would have a public IP address. All you'll have to do would be to apply src-nat (well, maybe a masquerade) on packets routed out via the l2tp interface, just as if it was a normal WAN interface.
If the router wouldn't have a public IP address itself, you may get in conflict with some other L2TP/IPsec client accessing the VPN service from behind the same publc address like your router. In that case, you would need to do a dirty trick on the Mikrotik to resolve that. If that is the case, come back for the details.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: MSN [Bot] and 32 guests
