phuketmymac
Running Netinstall from MacOs using Wine
Fri Feb 23, 2018 6:53 am
I am trying to get netinstall running on my Mac running High Sierra and Wine (winebottler)
Every single I try to open Netinstall, a message will pop up saying : Netinstall boot failure 10013
I can't run Wine as root as I am getting another error : LSOpenURLsWithRole() failed with error -10810 for the file /Applications/Wine.app
Anyone has tried and succeed?
It would be nice to be able to run that app without using Windows (Boot camp).
Thanks!
null31
Re: Running Netinstall from MacOs using Wine
Fri Feb 23, 2018 4:46 pm
Hi.
How the Netinstall uses port 67 UDP, you need to do a sudo (root) on wine to works.
Another option is to use a windows VM with bridged interface (and run as administrator).
psurmont
Sun Jul 15, 2018 3:56 am
I tried with sudo but no success still have a "bind bootp failed error". Tried with Wineskin and Win bottler no success. Any idea?
Pierre
spippan
Mon Oct 29, 2018 6:46 pm
also tried this to get working on MacOS X for years....
still no success ...
is there any "official" way (maybe a step-by-step guide for how to build with winebottler) to get NETINSTALL working on Mac OS X?
raiffeisen data center infrastructure and security
...stay curious
petertosh
Mon Oct 29, 2018 7:56 pm
Try:
sudo -H -u root "/Applications/Wine Stable.App/Contents/MacOS/wine" /path/to/netinstall.exe
Use your Wine, the path above is only an example. I managed to use it once this way. But haven't done it for a while....
A tutorial in German can be found here: https://blog.effenberger.org/2017/06/05 ... tallieren/
Best.
ofer
Tue Oct 30, 2018 12:26 pm
I did it using a network switch in between the computer and the router it seems to works much better
Users browsing this forum: No registered users and 57 guests
