shirazov
Bridge problem
Tue Feb 27, 2018 10:59 am
Hi guys. Please help me resolve this problem.
I have mikrotik CCR 1036 4g 12s
sebastia
Re: Bridge to Bridge connect problem
Tue Feb 27, 2018 11:43 am
Hi
Your current config is:
1 firewall: blocking communication between 172 & 10
2 routing: blocking routing between 172 & 10
But want them to be able to communicate, right ?
shirazov
Tue Feb 27, 2018 2:10 pm
please help me open this firewall and nat rule
sebastia
Tue Feb 27, 2018 2:28 pm
Start by removing all those listed rules: 2 firewall rules and 4 router rules.
"Default config" should be enough then. If not, please list your config:
/export hide-sensitive
shirazov
Tue Feb 27, 2018 3:30 pm
okey
poizzon
Tue Feb 27, 2018 9:33 pm
it seems your IP ROUTE table is empty ?
poi
sebastia
Tue Feb 27, 2018 10:01 pm
I don't see anything out of ordinary:
No firewall rules (except nat masq) => all is ACCEPTed
routing table no non-default entries: so should include connected routes for each network + default gateway from dhcp-client
=> please verify that?
So, should be working as is.
Few other remarks to look into later, but non-blocking:
* there is no need for a bridge with only 1 device in it
* interface list isn't in sync with bridge config, but currently not used
* dhcp pool naming scheme <> dhcp-server naming scheme???
shirazov
Wed Feb 28, 2018 8:09 am
sebastia
Wed Feb 28, 2018 5:37 pm
The inter-network (172 <-> 10) communication should be working as is. How did you verify that it isn't?
shirazov
Thu Mar 01, 2018 10:19 am
not working :( ok thanks for answering
sebastia
Thu Mar 01, 2018 10:46 am
What have you tried? Could you explain how "it is not working"?
I'm asking as from pure router configuration, the network level communication is allowed.
shirazov
Thu Mar 01, 2018 1:59 pm
client run: \\ftp share folder not opening
sebastia
Thu Mar 01, 2018 3:33 pm
Few things to check:
* can client & server connect to internet (=> this would indicate that they have proper network configuration)
* can you ping between 192 & 10, to any other system, if necessary disable temporary firewalls
* do you have some kind of filtering on server or client? (=> server-client works on 10 both, but not on 192)
Users browsing this forum: anav, Baidu [Spider], k6ccc, knowledgemonster and 42 guests
