esquirrel
[Fixed] Sudden loss of connectivity on wireless default wlan
Sun Mar 11, 2018 9:41 pm
[i]Note: this has been fixed- 'wlan1' had gotten disconnected from the bridge by mistake and it wasn't obvious at first what had happened.
The rest of the setup is very generic but I made some changes which may not have been the best decisions, still finding my way around. Feel free to make suggestions. I'm particularly interested in the best way to add additional subnets that dont share multicast with the wireless devices. Currently doing it with a simple extra subnet - and generic ethernet, layer 3.[/i]
original post:
I have what I think is the default wlan setup as generated by quickset, but inexplicably the wireless clients do not seem to be on the bridge and cannot ping the default gateway and home DNS server on the configured net. How can I verify that the default gateway and bridge is configured correctly? I am running the very latest stable OS revision on a hAp lite. It was working yesterday.
I have removed the nonessentials and anonymized the IP and mac addresses
set [ find default-name=ether3 ] disabled=yes
add admin-mac=CC:2D:XX:XX:XX:AC auto-mac=no comment=defconf fast-forward=no name=bridge protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-Ce country="mycountry" disabled=no distance=indoors \
frequency=auto mode=ap-bridge ssid=myssid wireless-protocol=802.11 wps-mode=disabled
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=profile1 supplicant-identity=""
add name=default-dhcp ranges=192.168.56.180-192.168.56.189
add address-pool=default-dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf edge=no-discover interface=*7
/interface bridge settings
set use-ip-firewall=yes
/ip settings
set accept-source-route=yes allow-fast-path=no max-neighbor-entries=1024 route-cache=no rp-filter=loose
/interface wireless access-list
add mac-address=XX:XX:XX:XX:XX:70 vlan-mode=no-tag
add address=192.168.56.1/24 interface=ether2 network=192.168.56.0
/ip arp
add address=192.168.56.10 interface=bridge mac-address=XX:XX:XX:XX:XX:61
add address=192.168.56.20 interface=bridge mac-address=XX:XX:XX:XX:XX:B7
/ip dhcp-client
add comment=defconf dhcp-options=clientid,clientid disabled=no interface=ether1 use-peer-dns=no use-peer-ntp=no
add address=192.168.56.0/24 comment=defconf dns-server=192.168.56.10 gateway=192.168.56.1 netmask=24 ntp-server=\
192.168.56.10
set cache-max-ttl=6h max-concurrent-tcp-sessions=1 max-udp-packet-size=512 servers=192.168.56.10
/ip dns static
add address=192.168.56.1 name=router.lan
add address=192.168.56.10 name=mydns.lan ttl=12h
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept ICMP" log=yes protocol=icmp
add action=accept chain=forward comment="defconf: accept in ipsec policy" disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=\
new in-interface-list=WAN
Users browsing this forum: tomek242 and 59 guests
