eripey
Securing your router
Mon Apr 23, 2018 5:52 pm
https://wiki.mikrotik.com/wiki/Manual:S ... our_Router
I am new to mikrtik and trying to configure the hex router. The above link gives instructions but stuck at disabling of mac-server part, after executing the command I get 'expected end of command'
Am I missing something here?
ochaconm
Trainer
Trainer
Re: Securing your router
Tue Apr 24, 2018 12:55 am
Post your command to see if there is any error.
An example to disable MAC-Server, MAC-Ping, and MAC Winbox on Ether1:
[admin@GissellaLojano] > tool mac-server print
Flags: X - disabled, * - default
 #    INTERFACE
 0 X* all
 1    ether1
[admin@Mikrotik] > /tool mac-server set 1 disabled=yes
[admin@Mikrotik] > /tool mac-server mac-winbox print
 #    INTERFACE
 0 X* all
 1    ether1
[admin@Mikrotik] > /tool mac-server mac-winbox set 1 disabled=yes
[admin@Mikrotik] > /tool mac-server ping print
  enabled: yes
[admin@Mikrotik] > /tool mac-server ping set enabled=no
#Print results
[admin@Mikrotik] > /tool mac-server print
 #    INTERFACE
 0 X* all
 1 X  ether1
 #    INTERFACE
 0 X* all
 1 X  ether1
  enabled: no
eripey
Tue Apr 24, 2018 4:13 pm
Ok, I did the following commands from the wiki securing your router and received the following...
[admin@MikroTik] > /tool mac-server set [find] disabled=yes
expected end of command (line 1 column 22)
I tried your example for the same and below are the same results.
[admin@MikroTik] > /tool mac-server set 1 disabled=yes
in both cases in the terminal window, the '[' and '1' are both red.
mrz
Tue Apr 24, 2018 4:42 pm
Discovery configuration syntax is changed, it uses interface lists now
https://wiki.mikrotik.com/wiki/Manual:I ... figuration
eripey
Tue Apr 24, 2018 4:50 pm
I'm not sure what you're saying. Can you give an example command to accomplish in securing the router?
mrz
Tue Apr 24, 2018 5:03 pm
eripey
Tue Apr 24, 2018 5:49 pm
Thanks! Those commands work now.
eripey
Tue Apr 24, 2018 5:53 pm
MikroTik caching proxy command has an extra 'set' in the command on the wiki.
mrz
Tue Apr 24, 2018 5:56 pm
fixed
Users browsing this forum: Bing [Bot] and 37 guests
