elcanijo
Balanceador con hAP AC Lite - Balancer with hAP AC Lite
Tue May 01, 2018 6:22 am
Hola, quiero saber si es posible utilizar la linea de los Routerboard hAC Lite para hacer balanceo de carga entre dos proveedores.
Hi, I want to know if it is possible to use the Routerboard hAC Lite line to do load balancing between two suppliers.
jarda
Re: Balanceador con hAP AC Lite - Balancer with hAP AC Lite
Tue May 01, 2018 7:07 am
Yes, it is.
This is the English only forum. No need to write your post in two languages, English is enough.
chechito
Wed May 02, 2018 5:17 pm
even the hap lite or the hap mini can be used to load balancing
Users browsing this forum: No registered users and 32 guests
