I have some Problems to setup my VLAN config. I hope someone can help me al little.
I have a new CRS328-24P-4S+ with RouterOS 6.42.1.
In my current Test Setup ether1 goes to the Router and ether24 to a PC.
VLAN10 should be for management the switch. This point works in my current setup.
And VLAN20 should be for PCs. This point doesnt work. I got no connection. And I cant figure out why.
I used parts from this manual:
https://wiki.mikrotik.com/wiki/Manual:CRS_Router
Here is my current setup:
Code: Select all
add name=bridge vlan-filtering=no
add bridge=bridge interface=ether1
add bridge=bridge interface=ether24 pvid=20
/interface vlan
add interface=bridge name=MGMT vlan-id=10
add address=192.168.99.2/24 interface=MGMT
add gateway=192.168.99.1
/interface bridge vlan
add bridge=bridge tagged=bridge,ether1 vlan-ids=10
add bridge=bridge tagged=ether1 untagged="ether24" vlan-ids=20
set bridge vlan-filtering=yes
