ddiaz
RouterOS Downgrade
Tue Jun 05, 2018 3:04 pm
I have a question, currently we have a microtik:
Architecture name: mipbse
Board name: RB2011UAS
Version: 6.33.1(stable)
And we want to change the router for a new one, current we bought a new one model:
Architecture name: tile
Board name: CCR1009-7G-1C
Version: 6.38.5
I would like to do a RouterOS downgrade, 6.38.5 to 6.33.1
but with tile arhitecture.
When I put the routeros-tile-6.33.1.npk in file list and then inSystem > package
push to "Downgrade" after this the router restart, but the router doesn't change version ... :(
I tried also with the file all packages...put in folder "Files List" folder ..
But nothing...
What is the problem....???
Thanks for your help
leoservices
Trainer
Trainer
Re: RouterOS Downgrade
Wed Jun 06, 2018 5:51 am
Hello
You are following the correct procedure; Just check if the file was not subfoldered. Example: /hotspot
What does the newer version do not answer?
I try to help !
Leonardo Vieira
https://youtube.com/contractti
Like Facebook.com/contractti
mlenhart
Wed Jun 06, 2018 8:25 am
make sure also that 6.33.1 is supported for CCR1009-7G-1C. You can check it in System -> Resources and check for "Factory Software" You can not go lower than this version.
dasiu
Trainer
Trainer
Wed Jun 06, 2018 11:42 am
That's probably the issue. 6.33.1 is November 2015 - probably this model is too new to be supported by that software.
antonsb
Wed Jun 06, 2018 5:13 pm
You can't downgrade to version lower than factory installed version.
Users browsing this forum: No registered users and 58 guests
