yourcrewtech
haplite bandwidth only getting 10 percent of the subscribed plan
Thu Jun 07, 2018 3:02 pm
im having issues on the bandwidth i recieved when using haplite router compared to my subscribed plan. When i plug directly to the modem im having 20 mbps but when i used the haplite router im only recieving less than 2 mbps. Can you guide me to the correct basic settings.
Would appreciate if you can provide a link or guidance on the basic settings.
Thanks,
jarda
Re: haplite bandwidth only getting 10 percent of the subscribed plan
Thu Jun 07, 2018 3:31 pm
Reset the router to defaults and use quickset.
yourcrewtech
Fri Jun 08, 2018 2:06 pm
I did reset several times and used the quick set but having the same result.
Appreciate you guidance on how can i maximize my plan speed.
jarda
Sat Jun 09, 2018 4:59 pm
Check tool profile during the maximal traffic load.
yourcrewtech
Sun Jun 10, 2018 1:52 pm
Hi Jarda,
Thanks for your message!
Sorry i'm noob and i don't know what is expected on the tool profile or what does the values means?
Here is what i encountered. Upon setting the Home AP thru quick set the first time, i'm getting the maximum speed of my subscribed plan. However after few hours of not using internet when i check the speed via FAST.com its showing less than 2 MBPS or sometimes only kbps. Is there a particular settings that needs to done? Or whatever configurations required so i can maximize the speed of my plan?
Appreciate your guidance.
Regards,
jarda
Sun Jun 10, 2018 2:39 pm
See the traffic on the wan interface. Check your wan is not opened for dns requests. If yes, correct your firewall accordingly.
diddie17
Mon Jun 11, 2018 3:52 pm
Just to remove any confusion, you may already understand the differennce, but if you don't, please make sure you understand the difference between MBps and Mbps as per http://home.earthlink.net/~flatlinecs/id48.html
I've seen both written in the thread, and I'm unsure as to what you are working with.
As an example, 2MBps is the equivilent of 16Mbps.
yourcrewtech
Tue Jun 19, 2018 5:04 am
Hi Jarda,
Im new with mikrotik and im used to plug and play router. Appreciate if you can give me guide how to do your instructions.
Regards,
yourcrewtech
Tue Jun 19, 2018 5:05 am
Hi diddie17,
Sorry for the confusion but its 2Mbps only.
Regards,
jarda
Tue Jun 19, 2018 3:18 pm
Guide: implement firewall rules for all 3 chains with connection tracking and final drop. Put all exclusions before. Exclude individually only those traffic types you really want to pass.
Users browsing this forum: No registered users and 25 guests
