Hoov
Cannot login to Access point from home
Sun Jun 17, 2018 7:16 am
At home I am connected to the access point thru a RB952Ui-5ac2nD-US then thru a Groove-52HPn. I have full internet access. Everything works. But I cannot use winbox or even a browser to login to the access point. It will not even respond to a ping from the CLI in either device. Yet I can go over to the tower and connect thru the access point directly and get right in using winbox, or even tiki-app. The access point is a RBMetal2SHPn. I have checked the firewall on all three devices and there is nothing blocking it. I can go to any other customers residence and login thru winbox into that access point. This problem only occurs thru my bridge and router. We use two IP ranges, 10.100 for the infrastructure and 10.110 for the clients. If I hook directly to my bridge and give my computer a 10.100 address it connects. The same holds true for my router. But with the 10.110 range I can login to every other network device in the system with no problem. I have checked thru the firewall, and even disabled the rules and it makes no difference. Does anyone have any idea what might be causing the problem in this access point?
CZFan
Re: Cannot login to Access point from home
Sun Jun 17, 2018 5:22 pm
Sounds like you might have a routing problem.
Can you provide output of "export hide-sensitive"?
MTCNA, MTCTCE, MTCRE & MTCINE
Hoov
Sun Jun 17, 2018 10:21 pm
I did do a bit of editing, I removed the serial number of the radio, the last half of the MAC address's that are shown, and the SSID. The rest is as is.
This is the Access Points file.
# jun/16/2018 19:57:15 by RouterOS 6.42.2
# software id = H9BB-RW43
# model = Metal 2SHPn
# serial number = xxxxxxxxxxxxxx
add fast-forward=no name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n default-authentication=no \
disabled=no frequency=2442 mode=ap-bridge ssid=radio1 \
wireless-protocol=802.11
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
# DHCP server can not run on slave interface!
add address-pool=default-dhcp authoritative=after-2sec-delay disabled=no \
interface=ether1 name=defconf
add bridge=bridge1 interface=wlan1
add bridge=bridge1 hw=no interface=ether1
set discover-interface-list=discover
add interface=ether1 list=discover
add interface=bridge1 list=discover
add interface=wlan1 list=mac-winbox
add interface=ether1 list=mactel
add interface=wlan1
/interface wireless access-list
add mac-address=64:D1:54:
add mac-address=68:72:51:
add mac-address=C0:D9:62:
add mac-address=CC:2D:E0:
add mac-address=28:C6:3F:
add mac-address=AC:5F:3E:
add mac-address=E0:98:61:
add mac-address=5C:51:4F:
add address=192.168.88.1/24 comment=defconf disabled=yes interface=ether1 \
network=192.168.88.0
add address=10.100.0.7/24 interface=wlan1 network=10.100.0.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=bridge1
set allow-remote-requests=yes
/ip dns static
add address=10.100.0.7 name=router
add action=accept chain=forward comment="defconf: accept established,related" \
connection-state=invalid
# in/out-interface matcher not possible when interface (wlan1) is slave - use master instead (bridge1)
connection-state=new in-interface=wlan1
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
# in/out-interface matcher not possible when interface (ether1) is slave - use master instead (bridge1)
add action=drop chain=input in-interface=ether1
add distance=1 gateway=10.100.0.1
/system clock
set time-zone-name=America/Detroit
/system identity
set name="Radio1 AP"
/system routerboard settings
set silent-boot=no
/system watchdog
set watchdog-timer=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
This is my Bridge,
# jun/17/2018 12:07:53 by RouterOS 6.42.3
# software id = 82VZ-G38A
# model = Groove 52HPn r2
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
disabled=no frequency=2412 mode=station-bridge radio-name="My CPE" \
ssid=LSBB@coville.2 wireless-protocol=802.11
add name=WAN
add name=LAN
/ip hotspot profile
add name=dhcp_pool0 ranges=10.110.0.2-10.110.0.254
add address-pool=dhcp_pool0 interface=bridge1 name=dhcp1
/system logging action
set 1 disk-lines-per-file=1
add interface=wlan1 list=WAN
add interface=ether1 list=LAN
add address=10.110.0.5/24 interface=ether1 network=10.110.0.0
/ip dhcp-client
# DHCP client can not run on slave interface!
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=10.110.0.0/24 gateway=10.110.0.1
set servers=71.10.216.1,1.1.1.1,1.0.0.1
add distance=1 gateway=10.110.0.1
/snmp
set contact=e-mail address location=Home src-address=10.110.0.5
/system clock
/system identity
set name="My CPE"
/system logging
set 0 action=disk
set 1 action=disk
set 2 action=disk
set 3 action=disk
/system ntp client
set enabled=yes primary-ntp=198.58.105.63 secondary-ntp=208.75.88.4
/system ntp server
set broadcast=yes broadcast-addresses=10.110.0.5 enabled=yes manycast=no
set auto-upgrade=yes silent-boot=no
/system scheduler
add interval=6h name=ReloadNTP policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=may/18/2018 start-time=18:44:43
/system script
add name=ReloadNTP owner=lsbb policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="{\
\r\
\n:local ntpServer \"pool.ntp.org\"\r\
\n:local primary [resolve \$ntpServer]\r\
\n:local secondary [resolve \$ntpServer]\r\
\n/system ntp client set primary-ntp \$primary\r\
\n/system ntp client set secondary-ntp \$secondary\r\
\n}"
/system watchdog
Thanks for any help you can give me.
Hoov
Mon Jun 18, 2018 8:03 pm
Any idea's would be appreciated.
rodney465
Mon Jun 18, 2018 11:43 pm
I had the same problem and gave up hope then i my issue got resolved cause my subnet mask were 255.255.255.0 and i changed it to 255.255.255.224 then it work please note i got a /27 range hope it works for you
Hoov
Tue Jun 19, 2018 1:57 am
Did you just have to change it in the two radio's? Do you know why this worked? It appears you made the range smaller. I really do not have that choice.
Hoov
Tue Jun 19, 2018 2:12 am
One other thing that makes this crazy, there are other access points in the network that I can get into. One at 10.100.0.6 and one at 10.100.0.8 and I can login to both of them with no problem. So to me that makes me think there is nothing wrong with the network configuration or routes. There is a switch between the backhaul radio and the access point that I can only login to for 15 or 20 seconds before I am kicked off. These are the only two problem children in the entire network.
2frogs
Long time Member
Long time Member
Tue Jun 19, 2018 2:38 am
Well, there is a lot wrong with that config, but a possible cause for your troubles is the IP is on the wlan interface instead of the bridge.
/ip address add address=10.100.0.7/24 network=10.100.0.0 interface=bridge1
Hoov
Tue Jun 19, 2018 3:21 am
I only heard of RouterOS and Mikrotik a bit over a month ago when I started working with my startup ISP. They had started using Ubiquiti products and they know that firmware. So we are starting wayyy behind the eight ball. I am still figuring all this out, so any pointers you can give me would be appreciated.
Hoov
Tue Jun 19, 2018 4:28 am
Thanks for the suggestion 2frogs, but that did not work.
Hoov
Thu Jun 21, 2018 1:12 pm
Any other idea's? We are at a loss.
slavisar
Wed Sep 04, 2019 12:43 pm
Maybe I have stumbled upon solution.
I have had the same problem with couple of Disc lite5.
After setting device as ap-bridge, it becomes invisible to winbox and ping.
Station side, I could connect to bridge-ap only by MAC.
AP side wise, ap-bridge was completely invisible.
Comparing setups I have found that interface list of station-bridge is fine but interface list of bridge-ap misses "bridge".
Add mannualy "bridge" and set as LAN.
After that, ap-bridge is fully available from both sides by IP or MAC.
Users browsing this forum: No registered users and 37 guests
