Ganuza
Trying to change a cheap TP-Link router for a cheap MikroTik one
Thu Jun 21, 2018 10:47 pm
I have to change a TP-Link router that is configured with a PPPoE user.
I was told that putting the MikroTik on PPPoE with the same user and password, the router on the same network (192.168.8.0/24, with .1 as gateway) and no DHCP (all the PCs have static IP on Windows) it will work.
But it doesn't.
When I change the TP-Link for the MikroTik, not even one PC gets connection to internet (I just unplug the WAN cable from the TP-Link and plug it on the MikroTik, port 1, and another ethernet cable that goes to a switch, port 2).
BUT, if I connect a PC into another port or using WiFi, that PC (with static IP on the 192.168.8.0/24 network) gets internet.
Edit to explain better the situation. Read from here.
There is a network using static IP on all of its devices. I need to change the router of that network for a MikroTik.
I configure PPPoE on the router MikroTik 941-2nD.Then I put the router on the 192.168.8.0/24 subnet, with 192.168.8.1 as gateway.
Deactivated DHCP, leave NAT checked (using Quick Set). Wireless disabled.
After that, I used some rules to block sites:
/ip firewall layer7-protocol
add name=facebook regexp="^.+(facebook).*\$" comment=FBK
/ip firewall mangle
add action=mark-connection chain=prerouting protocol=udp dst-port=53 connection-mark=no-mark layer7-protocol=facebook new-connection-mark=facebook_conn passthrough=yes comment=FBK
add action=mark-packet chain=prerouting connection-mark=facebook_conn new-packet-mark=facebook_packet comment=FBK
add action=drop chain=forward packet-mark=facebook_packet comment=FBK
add action=drop chain=input packet-mark=facebook_packet comment=FBK
The same with Messenger, Twitter and Instagram (You just change the site name on the command for the one that you want to block. All the "facebook" for "twitter" to block twitter).
After that, I made the change of routers.
I plug in the Internet cable on the Eth1 port. I plug in an Eth cable that goes to a switch on the Port 2.
Aaaand, the network doesn't have connection to Internet. Funny thing is, if I connect another PC on other port (3 or 4 of the MikroTik). That PC gets connection (previously configured with an static IP on the 192.168.8.0/24 subnet).
pe1chl
Re: Trying to change a cheap TP-Link router for a cheap MikroTik one
Thu Jun 21, 2018 11:23 pm
Show your configuration export (except the password)
anav
Thu Jun 21, 2018 11:24 pm
Which model of Mikrotik?
My understanding is that the default setup of the mikrotik is pretty much ready to go out of the box in terms of connectivity.
Before plugging any internet connection into it however, I would at least.
a. install winbox on my pc
b. access the mikrotik via winbox
c. change admin name to something else
d. apply a password to the new name.
Go to IP services and turn everything off except winbox.
Then test.... but before too long go through and apply the following unless not applicable.....
https://wiki.mikrotik.com/wiki/Manual:S ... our_Router
Standard expectation is that ether1 is WAN1 and ether2 is LAN on the default.
The LANIP structure is 192.168.88.1
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
ebreyit
Fri Jun 22, 2018 1:24 am
Please post config here
One possible omission is forgetting to add a NAT rule
Ganuza
Fri Jun 22, 2018 1:13 pm
# jun/22/2018 07:36:22 by RouterOS 6.42.4
# software id = 03IN-0M57
# model = RouterBOARD 941-2nD
# serial number = 846207E45A8F
add admin-mac=---------------- auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=\
    MikroTik-EFF85E wireless-protocol=802.11
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
    password=---------- use-peer-dns=yes user=----------------
add comment=defconf name=WAN
add comment=defconf name=LAN
add interface=bridge name=defconf
add comment=FBK name=facebook regexp="^.+(facebook).*\$"
add comment=SPD name=speedtest regexp="^.+(speedtest).*\$"
add comment=INS name=instagram regexp="^.+(instagram).*\$"
add comment=TW name=twitter regexp="^.+(twitter).*\$"
add comment=MSG name=messenger regexp="^.+(messenger).*\$"
add address=192.168.8.1/24 comment=defconf interface=ether2 network=\
    192.168.8.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1/ip dns
set allow-remote-requests=yes
/ip dns static
add address=192.168.8.1 name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=drop chain=forward comment=FBK packet-mark=facebook_packet
add action=drop chain=input comment=FBK packet-mark=facebook_packet
add action=drop chain=forward comment=SPD packet-mark=speedtest_packet
add action=drop chain=input comment=SPD packet-mark=speedtest_packet
add action=drop chain=forward comment=INS packet-mark=instagram_packet
add action=drop chain=input comment=INS packet-mark=instagram_packet
add action=drop chain=forward comment=TW packet-mark=twitter_packet
add action=drop chain=input comment=TW packet-mark=twitter_packet
add action=drop chain=forward comment=MSG packet-mark=messenger_packet
add action=drop chain=input comment=MSG packet-mark=messenger_packet
/ip firewall mangle
add action=mark-connection chain=prerouting comment=FBK connection-mark=\
    no-mark dst-port=53 layer7-protocol=facebook new-connection-mark=\
    facebook_conn passthrough=yes protocol=udp
add action=mark-packet chain=prerouting comment=FBK connection-mark=\
add action=mark-connection chain=prerouting comment=SPD connection-mark=\
    no-mark dst-port=53 layer7-protocol=speedtest new-connection-mark=\
    speedtest_conn passthrough=yes protocol=udp
add action=mark-packet chain=prerouting comment=SPD connection-mark=\
    speedtest_conn new-packet-mark=speedtest_packet
add action=mark-connection chain=prerouting comment=INS connection-mark=\
    no-mark dst-port=53 layer7-protocol=instagram new-connection-mark=\
    instagram_conn passthrough=yes protocol=udp
add action=mark-packet chain=prerouting comment=INS connection-mark=\
    instagram_conn new-packet-mark=instagram_packet
add action=mark-connection chain=prerouting comment=TW connection-mark=\
    no-mark dst-port=53 layer7-protocol=twitter new-connection-mark=\
    twitter_conn passthrough=yes protocol=udp
add action=mark-packet chain=prerouting comment=TW connection-mark=\
    twitter_conn new-packet-mark=twitter_packet
add action=mark-connection chain=prerouting comment=MSG connection-mark=\
    no-mark dst-port=53 layer7-protocol=messenger new-connection-mark=\
    messenger_conn passthrough=yes protocol=udp
add action=mark-packet chain=prerouting comment=MSG connection-mark=\
    messenger_conn new-packet-mark=messenger_packet
/system clock
set time-zone-name=America/Argentina/Cordoba
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
Another thing. I disable wireless (Interfaces - right click - disable), shut down the router and when it turns on, wireless is on again.
A friend known said to me that check that all the portr were on the same bridge and that check the masquerade (I don't know what that is).
pe1chl
Fri Jun 22, 2018 8:01 pm
The config does not look so bad, so you will have to debug it.
First check if the PPPoE interface is coming up and obtains an external IP address.
Then try with your censorship dropping and marking rules disabled to see if they maybe block all the traffic.
Note that such filtering is very CPU intensive and probably will not work well either. When such broad
terms are filtered you will block much more than those services themselves, maybe due to something I oversee
now you are effectively blocking everything.
Ganuza
Mon Jun 25, 2018 12:39 pm
The PPPoE gets IP. The weird thing is that I was able to connect to internet through the interface 3 by connecting another PC directly (with static IP on the 8.0/24 range) and the same with WiFi.
I do want to test with a clean config (just PPPoE and the 8.0/24 subnet. And maybe there is something with the eth 2 port? (Even though it doesn't look like that) So I also want to try connecting the network on the eth 3 port (I didn't try that).
We want to make the exchange to measure the CPU usage with a filtering method (and that one is the only one that I found that works), so although it would be bad if it crashes, we do are prepared for the eventual crash of the device.
In approximatly 8 hours I'm gonna test and post the results here.
Thanks for your help!
pe1chl
Mon Jun 25, 2018 1:50 pm
The setup of the ethernet ports looks fine. I would recommend disabling the special rules for censorship (filter, mangle) and try if it works.
Doing content filters this way is CPU intensive and has a risk of false positives.
Ganuza
Mon Jun 25, 2018 8:37 pm
Well.. I did the change with a MikroTik router with just PPPoE user and pass, LAN IP (192.168.8.0/24) and DHCP disabled. It didn't worked.
I have no fucking clue of what the problem might be.
Can it be something that is configured on the TP-Link and it's missing on the MikroTik?
pe1chl
Mon Jun 25, 2018 10:10 pm
Maybe this:
/ip firewall mangle
add action=change-mss chain=forward new-mss=clamp-to-pmtu passthrough=yes \
protocol=tcp tcp-flags=syn
althouugh it should also be sufficient to have the change-mss option enabled on the PPPoE interface.
of course with such a config you also need the masquerade option that you had in the shown config, and the PPPoE interface must be in the WAN interface list.
It is a basic config used by many users who have internet with PPPoE, including me.
mducharme
Trainer
Trainer
Mon Jun 25, 2018 10:27 pm
I think I can see the problem. You have told your MikroTik that if a computer tries to access facebook, speedtest, instagram, twitter, or messenger, that it should prevent that computer from being able to make any DNS queries afterwards for any websites. If it can't look up any names then you essentially cannot browse the Internet. If someone's browser tries to access anything with facebook in the name their DNS will be blocked completely and they will not be able to access any sites. I assume that is not what you want?
ex. if the customer has any messenger program installed on their computer that tries automatically to resolve something with "messenger" in the name then their Internet will get blocked after that. If it tries to connect to messenger right away then they will get blocked right away.
EDIT: I am mistaken, it seems that each DNS request starts up a separate connection so that extra requests should not get blocked. I just tested your config on my device and it worked. What RouterOS version do you have?
Ganuza
Tue Jun 26, 2018 2:20 pm
Hi, I'm using 6.42.4 (stable) and WinBox 3.14. On the firsts tests I was using 6.42.2 (stable).
I thought about some security configuration beyond the router (maybe on the switch where all the PCs are connected) but then I remembered that by connecting a notebook (with a randon IP from the same subnet) by ethernet and WiFi, I had connection to Internet.
I found the configuration to block sites here on the forum. I am new on MikroTik, so there is a lot that I don't understand about the terminology of this devices.
Another thing, I configured the router (using static IP, no DHCP) testing on another PPPoE account connected to a modem/router on bridge mode and it was working fine, with and without the blocking configuration. (on both 6.42.2 and .4 stable versions).
pe1chl
Tue Jun 26, 2018 2:36 pm
Because there are apparently so many overzealous operators who want to restrict what their clients can visit, there are many examples of "block this block that" configs to be found.
Unfortunately the usually block much more than the (usually beginner) poster knows, and others become the victim of that.
In todays internet it is not so straightforward anymore to block specific services. The network is adapting to such blocks and working around them.
You need to ask yourself if it is really necessary to do these blocks and if so, use more advanced methods to do it.
And even then, it will be piece-of-cake for your users to work around it when they want.
Ganuza
Tue Jun 26, 2018 6:26 pm
That is truth. But, in this scenario, the navigation (with the restrictions applied) works fine if I connect a PC directly to the router (it's not that the CPU reaches 100% usage and it freezes or I' blocking something that I don't want to block).
About the last sentence, can you tell me how to work around the blocking method that I found? It would be of help.
Edit: I just saw your last post. What does that script do?
pe1chl
Tue Jun 26, 2018 7:08 pm
Any VPN service will cut around your efforts... and when you want to block those too you will again have a lot of services to watch and block.
Ganuza
Fri Jun 29, 2018 8:34 pm
So, by just using Opera (that has VPN) I should be able to bypass this? I'm gonna try it.
Edit: Just did it, and yes. It's that easy..But well, this is what we can do with the tools that we have.
Ganuza
Tue Jul 03, 2018 5:54 pm
This seems dead, but I will continue updating.
I just connected the router (using another PPPoE user) to a clean switch. From the router I went to another router on bridge mode (needed for DSL) and connected two PCs into the switch.
The PCs with static IP. The router without DHCP. It worked.
Muqatil
Trainer
Trainer
Tue Jul 03, 2018 7:58 pm
Export again your config with the latest changes and the suggested cleanup.
Let's have a look.
Renato Bernardi
skype: medtech5
Ganuza
Tue Jul 10, 2018 7:24 am
There are no new configs. I just took a brand new Router, put the network and PPPoE, disabled DHCP and plugged the ethernet cables. (Without any kind of filter or any other config beyod the basic)
Someone said that the bridge may be the problem. But why that would be a problem with a certain network but not with another?
PS: In around 6 hours I'm gonna update this with the latest config that I used. I don't have the devices with me.
# jul/05/2018 14:37:54 by RouterOS 6.42.4
# software id = MR82-JA9L
# serial number = ---------------------
/interface wireless
    MikroTik-EFF972 wireless-protocol=802.11
    password=--------- use-peer-dns=yes user=----------
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=----------- \
    wpa2-pre-shared-key=-------------
add address-pool=default-dhcp interface=bridge name=defconf
    192.168.9.0
/ip dhcp-client
add address=192.168.8.0/24 comment=defconf gateway=192.168.9.1 netmask=24
set allow-remote-requests=yes servers=200.110.160.135
/ip dns static
    invalid
/system clock
set silent-boot=no
/tool mac-server
Muqatil
Trainer
Trainer
Tue Jul 10, 2018 6:32 pm
The gateway is outside the configured network... It's not gonna work. Perhaps it's a typo?
    192.168.9.0
The network is again outside your network
you are giving out IP addresses outside the interface range..
You should definitely make your mind which network range you wish to use :)
Renato Bernardi
skype: medtech5
Ganuza
Tue Jul 10, 2018 8:06 pm
Oh, sorry. It's not like that.
I changed the IPs on the .txt before paste it here.
In this case, the network is 192.168.8.0/24, with no DHCP, so the DHCP range shouldn't matter, right?
So, network 8.0/24, gateway 8.1 and no DHCP (the DHCP box is unchecked on the quick config screen. The PCs have static IP).
Ganuza
Wed Jul 11, 2018 12:26 pm
If I understand correctly, all the interfaces but the eth 1 (WAN) are on bridge, right?
diddie17
Thu Jul 12, 2018 2:50 pm
If I understand what you are trying to do, yes that's correct.
The Bridge is effectively joining those ports together into a switch. Anything outside of that switch will need to be routed to. In your configuration I think you want all of the internal ports to be switched and able to communicate freely with each other. The WAN link though is only to be routed to and the ip address for it will be on a different subnet and you will want a firewall in between.
Users browsing this forum: Baidu [Spider], pkropf and 31 guests
