Spartacus
cAP AC sync system time
Mon Jul 02, 2018 9:58 pm
i wanted to install an ntp-client on a cAP AC, but it seems to be that the device will sync the systemtime over CAPsMAN automatically. Is this correct, or do I need to configure a ntp client on the cAP?
I cannot find any configuration in cAP config file
Christian
Plutone
Re: cAP AC sync system time
Thu Jul 05, 2018 1:45 am
/system ntp client
set enabled=yes primary-ntp=193.140.100.40 secondary-ntp=217.198.219.102
AlainCasault
Trainer
Trainer
Thu Jul 05, 2018 1:55 am
And disable sync time in /ip cloud. There were sync issues before. Probably fixed now but why have two sources right?
Sent from Tapatalk
___________________________
Alain Casault, Eng.
If I helped you, let me know!
Spartacus
Fri Jul 06, 2018 7:05 pm
the cAP is managed by capsman and my question was, if the cAPS will sync automatically via capsman, without any additional config on the cAP.
Sync time in /ip cloud is enabled (by default), but from which source is it synchronized, from internet? If yes, is it better to add the local router (RB3011) as timeserver with this command?
/system ntp client
set enabled=yes primary-ntp=<gw-Address>
Christian
Users browsing this forum: JardinEspanol, Sob and 36 guests
