mbfound
Routerboard boot loop
Tue Jul 10, 2018 3:14 pm
Hi all,
I have an RB411 that is stuck in a bootloop after upgrading it from ROS 3. This is more for interests sake than actually fixing it, client is already using a new LHG.
It was on ROS 3. Upgraded it to 4 since that was licensing max. After that it licensed allowed up to 6 so I threw on the latest 6.43.5 and it never completed.
I've had issues upgrading RB133's (should go straight to bin) before but the 4-series never gave me any problems until now.
It's stuck in a loop, it does its first beep and restarts the cycle. Trying to netinstall the device only gives a "deeper" beep when it should enter netboot mode.
Anyone have any info regarding this?
Cheers,
mb
LucZWFM
Re: Routerboard boot loop
Wed Jul 11, 2018 8:57 am
Did you connect the device directly to a PC's LAN port? In windows this will not work
because the NIC doesn't come up due to that the the router's NIC isn't up. Connect the
router via a switch to the PC that you are running netinstall from this will bring up the
PC's NIC so it can do a netinstall.
Volunteer Techie @ZuidWest FM / ZuidWest TV, Stichting Repeater Bergen op Zoom & WRLP CB Repeater
Users browsing this forum: mkx, mur, nichky and 51 guests
