boma
IP/Services is all disabled
Fri Aug 10, 2018 12:51 pm
Hi everyone!
I'm a loser. I disabled all the services ports, including winbox (8291) and ssh.
The MikroTik is working well, but I can't connect to it. What can I do to restore access? I also have a physical access to device. The model is MikroTik RB3011UiAS-RM.
Is there any solution for this case?
P.S. I found some manual about netinstall utility. Does it help?
pukkita
Trainer
Trainer
Re: IP/Services is all disabled  [SOLVED]
Sat Aug 11, 2018 11:46 am
Doesn't it appear on Neighbors tab of Winbox? If so, click on the router Mac-address to connect via Mac-winbox.
If it doesn't, you can gain access to the 3011 in order to reenable networking services by using the Serial Console port, RJ45 on the back of the RB3011.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
boma
Sat Aug 11, 2018 1:34 pm
Thanks, I didn't think it would help, but it does.
Users browsing this forum: No registered users and 22 guests
