drillstring
Add DHCP server to VLAN???
Sat Aug 11, 2018 12:10 am
I hav set up a test set as per enclosed drawing and i cannot get the dhcp working on the vlan. I must do something wrong, but what????
RouterOS version 6.42.6
Router hAP lite
Internet access set to automatic on eth1 (gets IPp address etcetera from DHCP server from ISP)
Firewall router, NAT and DHCP are set
Local network IP address 192.168.88.1
Netmask 255.255.255.0/24
DHCP range 192.168.88.10-192.168.88.254
two smart switches are connected to port eth2 and eth3 (see drawing) and the tagged VLANs are connected by the following command
/interface bridge vlan add bridge=bridge1 tagged=ether2,ether3 vlan-ids=220,223,230
/interface bridge set bridge1 vlan-filtering=yes
The RouterOS makes a dynamic VLAN
When device A & B set with fixed IP's (in the same sub net) and connected to the VLAN 222 ports on the switches, communication is working.
I like to connect a DHCP server to this VLAN 222 but without succes.
I connected VLAN to the bridge1 in the interface list as follow:
/interface vlan add interface=bridge1 name=vlan222 vlan-id=222
and added IP address to the VLAN:
/ip address add address=192.168.222.1/24 interface=vlan222 network=192.168.222.0
made a pool for the DHCP server
/ip pool add name=dhcp-pool-vlan222 ranges=192.168.222.100-192.168.222.200
Added DHCP server and network (gateway not required yet)
/ip dhcp-server add name=dhcp-vlan222 interface=vlan222 address-pool=dhcp-pool-vlan222
/ip dhcp-server network add address=192.168.222.0/24
enabled the dhcp server via WinBox
Device A & B do net get an IP address from the router (device A & B are set to request an IP from a DHCP server)
English is not my native language, apologize for grammar and spelling mistakes
diddie17
Re: Add DHCP server to VLAN???
Sat Aug 11, 2018 1:40 pm
Might just be a typo when you typed up the post, but the pool definition looks wrong -
made a pool for th eDHCP server
/ip pool add name=dhcp-pool-vlan222 ranges=192.169.222.100-192.168.222.200
I think the starting range should be 192.168.222.100 not 192.169.222.100
drillstring
Sat Aug 11, 2018 3:03 pm
You are correct, it is a typo, in the setup i used 192.168.222.100. I updated the original post
pe1chl
Re: Add DHCP server to VLAN???  [SOLVED]
Sat Aug 11, 2018 3:11 pm
You should add the bridge1 to the vlan222 as well (tagged). Just like was automatically done for vlan 1, see your picture.
Without that, you cannot connect the vlan222 subinterface to the bridge (you can, but it is not connected to the actual VLAN).
drillstring
Sat Aug 11, 2018 4:37 pm
I have done as you mentioned and it is working, Thanks
Users browsing this forum: No registered users and 24 guests
