miyago
Understanding Default config: bridge
Wed Aug 15, 2018 4:43 pm
Hello
I'm going through the mikrotik default config of my RouterBOARD 962UiGS-5HacT2HnT hAP ac to understand it all.
My question was about bridge configuration. It's my understanding bridge is used to devide networks into segments.
Looking at the config it seems one bridge is created, not to divide but in order to communicate through mac-addresses, is that correct?
If I remove the bridge would devices need to communicate through IP addresses or could they not communicate at all?
# aug/15/2018 15:28:48 by RouterOS 6.43rc51
# model = RouterBOARD 962UiGS-5HacT2HnT
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether4 ] name=ether4-NAS
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country=sweden disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=Mikrotik1 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country=sweden disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=Mikrotik2 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=XXXXX wpa2-pre-shared-key=XXXXX
add bridge=bridge comment=defconf interface=ether4-NAS
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=ether1-WAN list=WAN
Cha0s
Forum Veteran
Forum Veteran
Re: Understanding Default config: bridge
Wed Aug 15, 2018 4:47 pm
The bridge does what it says. It bridges multiple ports/interfaces together. It's pretty much a "software switch".
https://en.wikipedia.org/wiki/Bridging_(networking)
In this instance it will take all interfaces (except the first one) and make them act as a switch so all of them can communicate with each other.
miyago
Wed Aug 15, 2018 8:16 pm
Thank you, so without it there can be no comunication?
bramwittendorp
Wed Aug 15, 2018 8:27 pm
You can certainly use a MikroTik device without a bridge, but for SoHo-use you'll probably be better of with a bridge.
Without a bridge the router will be in routed mode, in that case every interface of the router needs it's own ip-address and when devices are trying to reach other network segments they will be routed by the MikroTik.
So, yes communication is possible with a bridge but for a device like a hAP ac it's a good idea to use it with a bridge, as this will give similar behavior as most SoHo-routers.
Bram - MikroTik enthusiast - MTCNA / MTCRE / MTCWE / MTCIPv6E
Don't be shy, share your /export hide-sensitive and make sure to read this.
k6ccc
Thu Aug 16, 2018 5:36 pm
It depends on what you are doing. I am not using a bridge on any of my routers. However, I am using my routers exclusively as routers. Each port is either a separate LAN or a trunk port with multiple VLANs. Everything is routed in between ports. Each port is connected to a different port of a managed switch that handles switch functions.
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
Users browsing this forum: No registered users and 39 guests
