olivier56
2 dhcp on same router
Wed Aug 15, 2018 8:50 pm
Hello
sorry for my English..
i have a router with the capmanager activate.
i have two configuration 1 wifi-lan and the other wifi-home automation.
a dhcp in 192.168.2.x for my lan and wifi lan.
I wish to have a dhcp for wifi-home automation in 192.168.3.x.
I galley a little for the interface to take for the 2nd dhcp.
Thanks for your help
poizzon
Re: 2 dhcp on same router
Thu Aug 16, 2018 10:00 pm
create two WiFi SSID's, and then assign with different subnet
poi
mkx
Thu Aug 16, 2018 10:20 pm
First you need to define another address pool then DHCP server network and lastly bind DHCP server with correct pool and network to desired interface:
add name=home_automation ranges=192.168.3.20-192.168.3.254
add address=192.168.3.0/24 dns-server=<enter DNS server to be used by clients here> gateway=192.168.3.1 netmask=24
add address-pool=home_automation interface="wifi_home automation" name="dhcp_home automation"
Review the above commands and adjust them to your setup (IP address range, DNS server address, gateway address - this should match IP address bound to "wifi_home automation" interface ... and correct name of said interface).
BR,
Metod
olivier56
Fri Aug 17, 2018 6:59 pm
Hello
thanks for the help.
my config for the dhcp and capsmanager and dhcp
/caps-man datapath
add bridge=bridge interface-list=all local-forwarding=yes name=datapath1
add bridge=br_domotique local-forwarding=no name=datapath2
/caps-man security
add authentication-types=wpa2-psk name=SEC-Wifi-maison passphrase=*****
add authentication-types=wpa2-psk name=Domotique passphrase=*******
/caps-man configuration
add country=france datapath=datapath1 datapath.client-to-client-forwarding=no \
datapath.local-forwarding=no distance=indoors mode=ap name=Maison security=\
SEC-Wifi-maison ssid=Wifi-Maison
add country=france datapath.bridge=br_domotique \
datapath.client-to-client-forwarding=no datapath.local-forwarding=no \
distance=indoors mode=ap name=Domotique security=Domotique ssid=Test
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled comment=local master-configuration=Maison \
name-format=prefix-identity slave-configurations=Domotique
---dhcp---
0 192.168.2.0/24 192.168.2.1 192.168.2.1 lan and wifi lan
1 192.168.3.0/24 192.168.3.1 192.168.3.1 Domotique
------DNS---
servers:
dynamic-servers: 192.168.1.254
allow-remote-requests: yes
max-udp-packet-size: 4096
query-server-timeout: 2s
query-total-timeout: 10s
max-concurrent-queries: 100
max-concurrent-tcp-sessions: 20
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 87KiB
i still have a problem at dns level. if i put dns 8.8.8.8 i have access to the web however if i put 192.168.3.1 no web.
I ping the IPs but not the dns names.
I do not understand why
thank you
mkx
Fri Aug 17, 2018 8:49 pm
I'm not sure how DNS server is configured now. Probably you have to enable it if it's not already. Be sure you don't allow connections to TCP and UDP ports 53 from internet.
set allow-remote-requests=yes servers=8.8.8.8
BR,
Metod
olivier56
Sat Aug 18, 2018 6:48 pm
i have a dns with my first lan:
ip dns print
servers:
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 298KiB
192.168.1.254 is Ip of my adsl box.
First lan: 192.168.2.*/24 dns 192.168.2.1 (ip router board) .
Second lan (with capsmanager) 192.168.3.*/24 if dns is 192.168.3.1 no resolution , i can ping ip no domain ..
if in configure dhcp for my second lan like this:
# ADDRESS GATEWAY DNS-SERVER WINS-SERVER DO..
0 192.168.2.0/24 192.168.2.1 192.168.2.1 (first dhcp)
1 192.168.3.0/24 192.168.3.1 192.168.1.254 (second dhcp)
I can ping domain name like google.fr.
BR
mkx
Sat Aug 18, 2018 11:17 pm
I can think of two reasons why you can't use RB's DNS server from your home automation: either there's some firewall rule blocking access to DNS service from 192.168.3.0/24 or CapsMan settings prevent it. Either way it's just guessing until you post full configuration.
BR,
Metod
olivier56
Sun Aug 19, 2018 8:15 pm
hi
my configuration
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 6.42.6 (c) 1999-2018 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
[admin@Capman-garage] > export
# aug/19/2018 19:10:36 by RouterOS 6.42.6
# software id = V4XF-HAYV
# model = CRS125-24G-1S-2HnD
# serial number = 786F083D7C15
add fast-forward=no name=br_domotique
add admin-mac=CC:2D:E0:0B:47:95 auto-mac=no comment=defconf name=bridge
add fast-forward=no name=fplayer
add fast-forward=no name=freebox
/interface wireless
# managed by CAPsMAN
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-0B47AD \
wireless-protocol=802.11
/interface vlan
add interface=ether1 name=ETHER1_VLAN100 vlan-id=100
add interface=ether5 name=ETHER5_VLAN100 vlan-id=100
/caps-man datapath
/caps-man security
add authentication-types=wpa2-psk name=SEC-Wifi-maison passphrase=..................
add authentication-types=wpa2-psk name=Domotique passphrase=P.........................
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=domotique
/caps-man datapath
/ip kid-control
add disabled=yes fri="" mon="" name=kid1 sat="" sun=20h-20h30m thu="" tue="" \
wed=""
add name=dhcp_pool1 ranges=192.168.2.100-192.168.2.150
add name=Domotique ranges=192.168.3.1-192.168.3.15
add address-pool=dhcp_pool1 disabled=no interface=bridge lease-time=1h10m name=\
dhcp1
add address-pool=Domotique disabled=no interface=br_domotique name=Domotique
/port
set 1 baud-rate=115200 data-bits=8 flow-control=none name=usb2 parity=none \
stop-bits=1
/caps-man manager
set enabled=yes
add bridge=fplayer comment="lan Freebox capsman" interface=ether2
add bridge=freebox comment="lan Freebox" interface=ether4
add bridge=bridge comment="lan Freebox" interface=ether5
add bridge=freebox comment="lan Freebox" interface=ether6
add bridge=freebox comment="lan Freebox" interface=ether7
add bridge=freebox comment="lan Freebox" interface=ether8
add bridge=bridge comment="lan Maison" interface=ether20
add bridge=bridge comment="lan Maison" interface=ether21
add bridge=bridge comment="lan Maison" interface=ether22
add bridge=bridge comment="lan Maison" interface=ether23
add bridge=bridge comment="lan Maison" interface=ether24
add bridge=bridge comment="lan Maison" interface=sfp1
add bridge=bridge comment="lan Maison" interface=wlan1
add bridge=freebox comment="lan Freebox" interface=ether1
add bridge=freebox comment="lan Freebox" interface=ether3
add bridge=bridge comment="lan Maison" interface=ether15
add bridge=bridge comment="lan Maison" interface=ether12
add bridge=bridge comment="lan Maison" interface=ether13
add bridge=bridge comment="lan Maison" interface=ether14
add bridge=bridge comment="lan Maison" interface=ether16
add bridge=bridge comment="lan Maison" interface=ether17
add bridge=bridge comment="lan Maison" interface=ether18
add bridge=bridge comment="Lan maison" interface=ether19
add bridge=fplayer comment="Lan FreePlayer" interface=ETHER5_VLAN100
add bridge=bridge comment="Lan Maison" interface=ether11
add bridge=fplayer interface=ETHER1_VLAN100
add bridge=bridge interface=ether9
add bridge=bridge interface=ether10
add comment=defconf interface=freebox list=WAN
add interface=br_domotique list=domotique
/interface wireless cap
set caps-man-addresses=192.168.2.1,192.168.2.254 discovery-interfaces=bridge \
enabled=yes interfaces=wlan1
add address=192.168.2.1/24 interface=bridge network=192.168.2.0
add address=192.168.3.1/24 interface=br_domotique network=192.168.3.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=freebox
/ip dhcp-server lease
add address=192.168.2.253 client-id=1:0:fd:45:fc:6e:18 mac-address=\
00:FD:45:FC:6E:18 server=dhcp1
add address=192.168.2.252 client-id=1:90:b1:1c:6f:3:f0 mac-address=\
90:B1:1C:6F:03:F0 server=dhcp1
add address=192.168.2.3 client-id=1:0:1d:73:a3:d:1c mac-address=\
00:1D:73:A3:0D:1C server=dhcp1
add address=192.168.2.5 mac-address=00:24:D4:71:72:BD server=dhcp1
add address=192.168.2.4 client-id=1:d8:fe:e3:5c:14:68 mac-address=\
D8:FE:E3:5C:14:68 server=dhcp1
add address=192.168.2.11 client-id=Domotique comment=Alexa mac-address=\
B0:FC:0D:06:FD:69 server=dhcp1
add address=192.168.2.12 client-id=Domotique comment="Alexa bureau" \
mac-address=C4:95:00:2C:89:83 server=dhcp1
add address=192.168.2.15 client-id=Domotique comment="Chambre EVA" mac-address=\
84:F3:EB:14:C5:7C server=dhcp1
add address=192.168.2.16 client-id=Domotique comment="Chambre angel" \
mac-address=84:F3:EB:14:C6:32 server=dhcp1
add address=192.168.2.10 client-id=1:b8:27:eb:5d:63:88 comment=\
"serveur domotique" mac-address=B8:27:EB:5D:63:88 server=dhcp1
add address=192.168.2.14 client-id=1:50:c7:bf:b6:c4:27 mac-address=\
50:C7:BF:B6:C4:27 server=dhcp1
add address=192.168.2.254 client-id=1:6c:3b:6b:3c:23:16 mac-address=\
6C:3B:6B:3C:23:16 server=dhcp1
add address=192.168.2.251 client-id=1:64:d1:54:f8:69:b8 mac-address=\
64:D1:54:F8:69:B8 server=dhcp1
add address=192.168.2.104 mac-address=B0:E1:7E:20:1A:F7 server=dhcp1
add address=192.168.2.0/24 caps-manager=192.168.2.1 dns-server=192.168.2.1 \
gateway=192.168.2.1
add address=192.168.3.0/24 dns-server=192.168.3.1,8.8.8.8 gateway=192.168.3.1
/ip dns static
add address=192.168.88.1 disabled=yes name=router.lan
add address=192.168.2.253 name=toto.lan
add action=drop chain=forward comment="prise tplink" log=yes out-interface=\
bridge src-address=192.168.2.14
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add action=dst-nat chain=dstnat comment=\
"Port Forward rdp verserveur hyperv2016" disabled=yes dst-port=124568 \
protocol=tcp to-addresses=192.168.2.252 to-ports=123456
/ip kid-control device
add mac-address=B0:E1:7E:20:1A:F7 name=eva user=kid1
add mac-address=C8:14:79:A3:A9:A7 name=test user=kid1
add check-gateway=ping disabled=yes distance=1 dst-address=172.16.0.0/23 \
gateway=192.168.2.106
/lcd
set time-interval=hour
/lcd interface pages
set 0 interfaces=wlan1
/system clock
set time-zone-name=Europe/Paris
/system console
add disabled=no port=usb2
/system identity
set name=Capman-garage
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
/tool netwatch
add disabled=yes host=192.168.2.150
/tool sniffer
set filter-interface=*C88
thank you for you help
BR
mkx
Re: 2 dhcp on same router  [SOLVED]
Sun Aug 19, 2018 9:21 pm
If I got it right the problem is that you have 3 interface lists: LAN, WAN and domotique. You have firewall rule
which doesnt allow to use RB's DNS service (among other things) from devices connecting through domotique interface list. As you probably don't want to allow full connectivity from home automation to router, it is probabky better to construct specific allow filters for DNS only
add action=accept chain=input comment="allow DNS from domotique" \
     in-interface-list=domotique protocol=udp port=53
     in-interface-list=domotique protocol=tcp port=53
You should place these two rules before the one quoted above which drops all on input chain.
BR,
Metod
olivier56
Sun Aug 19, 2018 9:59 pm
hi,
you got right :)
"Chapeau bas Monsieur" french exprission to says thank you an respect.
br
Users browsing this forum: monotsc and 33 guests
