thehay95
How to hide web interface of router from internet?
Mon Sep 03, 2018 1:47 pm
Hi! Just got my first RouterBoard. Is there any way to make web interface accessible only in local network and not from the outside (I have a white IP)?
I don't really like winbox and prefer using web interface instead, but I really dislike the idea that my router settings are public as hell. (if you noticed some mistakes, sorry, english is not my main language).
ADahi
Re: How to hide web interface of router from internet?
Mon Sep 03, 2018 2:14 pm
you can use firewall and you have to block public access to the router
mkx
Mon Sep 03, 2018 2:47 pm
Default firewall settings don't allow any access to management services (www,ssh,winbox,...) from WAN interface. You just need to keep /interface list member current.
BR,
Metod
BartoszP
Mon Sep 03, 2018 2:49 pm
IP/Services /WWW ... set available only from LAN subnet.
Real admins use real keyboards.
To quote or not to quote, there is the topic: viewtopic.php?f=2&t=168474
Jotne
Mon Sep 03, 2018 3:06 pm
Like mkx says, its not open form internet, only if you have added fw rules your self to do so.
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
stoser
Mon Sep 03, 2018 4:27 pm
The best way to restrict who can access specifically the www interface for administering the router is to do what BartoszP wrote. In the www interface or winbox, choose IP ---> services. Select www. Specify which IP addresses or subnets can access the www service. While you are at it, restrict winbox access, telnet access, ssh access, ftp access, api access, etc to certain IP addresses or subnets too, or simply disable the ones that you will not use.
It is also extremely important to highly restrict all communications coming from the WAN access to your router, and this is done via the IP ---> Firewall ---> Filter Rules. There are more forum posts than I can count that address this topic, so just look it up
Kind regards
Steveocee
Mon Sep 03, 2018 6:42 pm
As others have said, IP>Services and restrict it, best case firewall rule as well. Why not use Winbox and disable http&https altogether?
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
mkx
Mon Sep 03, 2018 9:36 pm
@Steveocee, in your opinion, what are pros of using Winbox over Webfig/SSL? Other than Winbox/MAC...
BR,
Metod
Jotne
Mon Sep 03, 2018 10:12 pm
Winbox support multiple windows open at the same time.
MikroTik->Splunk
Steveocee
Tue Sep 04, 2018 11:36 am
Multiple open tabs simultaneously which whilst it sounds unhelpful, it is very useful at times.
MAC (you've mentioned) which is a lifesaver sometimes
Fluidity, http just doesn't feel well polished, Winbox feels native and like it is the primary interface.
Security, most users would default to typing in gateway IP address to access router, if there is no http server then you are that bit more secure
It works, I find http sometimes doesn't apply changes or I'll back out of wireless interface and it'll end up restarting the interface.
Cross platform, it works on WIndows, Linux (I used it on Ubuntu with WINE for a couple of years), and I'm now using it on Mac thanks to Joshaven's package.
mkx
Tue Sep 04, 2018 12:12 pm
While I agree with most arguments by @Steveocee, I can't agree with the last one (about winbox being cross-platform). Web access is the most platform-independant thing in modern internet, no "thick client" can beat it. I've had my share of problems running winbox on my Windows7 x86 machines - it wasn't problem of firewall, it simply didn't start (threw some error). The most recent one (3.17) is fine with me so far.
BR,
Metod
solar77
Long time Member
Long time Member
Thu Sep 06, 2018 6:26 pm
winbox 3.1.7 have one issue with me: reconnect to a device, it won't open it in new window.
MTCNA MTCTCE UEWA
Users browsing this forum: mszru and 69 guests
