igorludak
Site to Site IPSec between two Mikrotik Routers
Mon Sep 24, 2018 10:27 pm
Hello All,
I`m trying to establish connection between two mikrotik routers but i cant make it possible they fail all time so here is my config:
I`m using two same RB2011UiAS-2HnD models.
Router 1 Config
igorludak
Re: Site to Site IPSec between two Mikrotik Routers
Mon Sep 24, 2018 10:42 pm
Router 2 Config
Is there any chance someone can tell me what i`m doing wrong ?
tippenring
Tue Sep 25, 2018 5:28 pm
Glancing over your screenshots, it looks about right for the IPSec. I'd tell you to make sure you exclude the subnets from masquerade or dst-nat, but you aren't getting that far yet.
Can your routers reach each other at all? It looks like they can't.
igorludak
Tue Sep 25, 2018 6:10 pm
Thanks for replay on my post.
Yes both routers are able to ping each other.
I also want to mention, the ISP provider is providing internet using private ip address and after that they attach static public ip. The public IP is not double nat that ip is attached only to my routers i can confirm that.
Sob
Tue Sep 25, 2018 7:50 pm
Last time I've seen send error for phase1, it was because local-address in peer config was incorrectly set to public address, which in fact wasn't local (router was behind NAT). You say you do have NAT, but you don't set local-address for peer. You may have similar problem with policy, but I guess it should not influence phase1. But I'm not 100%, so try to experiment with that anyway.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
xvo
Forum Veteran
Forum Veteran
Tue Sep 25, 2018 8:36 pm
I've had this when I messed up with the routes on one of the routers.
On the second one i had a time up error.
Double check firewalls and routes on both of the routers to be sure not only icmp passes, but everything else.
To rule out the firewall add the temporary rules accepting everything from the other router's ip on top.
igorludak
Wed Sep 26, 2018 8:27 am
Thanks for replay on my post. As i have share the photos there is no block rules before the IPSec rules. Still facing the same problem. I tried to connect using ISP private ip but without success and now the error is: Time up.
On other hand into remote peers i'm able to see the connection on both routers. I will share that photo later today
igorludak
Thu Sep 27, 2018 8:10 pm
Here is the strange information i`m seen into the Remote Peers
Does this means that the connections is established ?
Also i`m still seen the same error with Phase 1
Users browsing this forum: 7amod and 34 guests
