MUM Europe 2020
thomasp97
How can I check if my CAP is correctly provisioned by the CAPsMAN?
Thu Oct 11, 2018 5:29 pm
Hi everybody,
Is there a way to check if the CAPsMAN is provisioning my CAP's correctly?
I came across a (probably rare) issue where the cap showed me that the Wlan is working just fine (Picture 1). However, I faced some issues where the signal was very poor so I checked my Wi-Fi coverage and found out that this particular AP does not provide 2.4GHz Wlan.
Can anybody help me out?
nickshore
Re: How can I check if my CAP is correctly provisioned by the CAPsMAN?
Thu Oct 11, 2018 5:40 pm
Looks like you have it set on channel 3, and only g, what did you set it to on the capsman ?
You should make sure you are using non-overlapping channels, and the correct 802.11 protocols, such as g/n
Nick
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
thomasp97
Fri Oct 12, 2018 9:06 am
I didn't choose a channel manually.
Unfortunately my Wireless Devices (scanner for the warehouse) only support the g band. I Already had the g/n band enabled, but it only causes problems e.g. cant connect at all or there were even issues while roaming between the AP.
Capsman Channel:
name="CAP2GHz" band=2ghz-b/g extension-channel=disabled skip-dfs-channels=yes
name="CAP5Ghz" band=5ghz-onlyac extension-channel=disabled skip-dfs-channels=yes
Capsman Provisioning:
radio-mac=00:00:00:00:00:00 hw-supported-modes=ac identity-regexp="" common-name-regexp="PCAP-*" ip-address-ranges=""
action=create-enabled master-configuration=WLanInHouse5Ghz slave-configurations=WLanMD5Ghz,WLanProd5Ghz
name-format=prefix-identity name-prefix="CAP"
radio-mac=00:00:00:00:00:00 hw-supported-modes=g identity-regexp="" common-name-regexp="PCAP-*" ip-address-ranges=""
action=create-enabled master-configuration=WLanInHouse2Ghz slave-configurations=WLanMD2Ghz,WLanProd2Ghz
greetings,
Thomas
Users browsing this forum: chilliflakes and 50 guests
